What winch model # fits a D69U
Showing 1 to 6 of 6 results
dwfarm
Send a private message to dwfarm
I am going to look at a winch that a guy has and i was wondering how i would know if it will go on my D69U. Anybody have any idea of maybe a winch model # or something. And also what all do i need to make sure is with it to hook it up if it is in fact the correct one.
Thu, Oct 18, 2012 11:31 PM
Jason 10/D4
should be a 6n maybe or 6d or e model think the n seriesgoes on the u series tractors. Jason
Fri, Oct 19, 2012 1:52 AM
Reply to Jason 10/D4:
Most common is either the D6N or D6C. I would have to check on fit up for the Direct Drive D6D & E but I'm thinking they will work also.
Biggest challenge is usually getting all the controls and if the drum is bare of cable, getting the proper cable anchor attachment can be a hard to find unless it uses a standard ferrule.
Fri, Oct 19, 2012 3:37 AM
Mervyn Pepper
Send a private message to Mervyn Pepper
D6N was most common, but last U models had D6C. Later D and E winchs will fit so long as they came off a U or a D6B. stud patterns are same for all models. BUT pto shafts were different for tractors other than those 2.
Have seen some D6 9Us with carco model F and F7 winchs, but you would want to see them fitted to the tractor they came off.
All used a stand 'L' ferrule you want 3/4 or preferably 7/8 rope if your doing heavy pulls.
Fri, Oct 19, 2012 3:56 AM
snowshoveler
Send a private message to snowshoveler
Reply to Mervyn Pepper:
I hope the winch fits your D6.
Really just because want to see pictures of it and the install.
I would love to have the forestry winch setup for mine.
Might copy what you do eventually.
Chris
193? d4400 cat powerunit
1950 john deere M
1959 international t5 crawler
1977 powerking 1216 tractor
Fri, Oct 19, 2012 5:11 AM
Reply to snowshoveler:
Chris
Here is a picture of the Hyster D6C mounted to a 9U. Got plenty of pictures of D6N & C model winches that are dismounted from the tractors
in case you need to ID something.
Fri, Oct 19, 2012 6:20 AM
dwfarm
I looked at it from a distance one time. The older man that had it had removed it from one of his dozers years ago and had mounted it (rigged it) on a tandem truck that he had lift poles on. I bought my dozer from him about 3 months before he passed away. His son is going to scrap iron all his old stuff and I told him I would like to look at the winch and see if it will fit before they send it to China. I don't know how much modifying he had to do it to make it work for what he was doing with it. The best I remember it is a hyster winch. It is a little over 200 miles from me so I wanted to get as much info before I went this weekend so I don't have to make another trip. I'm going to get a shear blade from there that I bought with the dozer. I might as well get a winch too!!!! Thanks for all the info!
Fri, Oct 19, 2012 8:09 AM
