What was the Cat 22 (2F,1935) original starter motor?
Showing 1 to 10 of 20 results
Scott Kuehn
Send a private message to Scott Kuehn
I read it was the Delco Remy 736D, but can't find any more information on that.  We're restoring a 2F and had the factory starter, but it the starter missing when we rescued it.  It has the original ring gear, battery box etc.
Any chance anyone out there have any more information on the original starter or where we can find one?
Fri, Oct 11, 2024 8:47 PM
josh
Thank you received: 14
Delco Remy 736D is the correct starter.
Sat, Oct 12, 2024 3:25 AM
Scott Kuehn
Reply to josh:
Thanks for the reply. I contacted Delco Remy and explained what we're looking for and they said they didn't have any records of a 736D and their numbers were usually 7 digits. I've tried looking online for anything for a 736D and can't find anything.
Sat, Oct 12, 2024 6:06 PM
d2gary
I did a quick search and found this 39mt as a cross reference. I dont know anything more but here's the spec sheet. [attachment=77850]Screenshot_20241012-071146_Chrome.jpg[/attachment]
Sat, Oct 12, 2024 9:29 PM
GrantJ
Thank you received: 10
Reply to d2gary:
I suspect that there are other period starters that would work, but getting the correct gear may be the biggest issue. I put a modern starter on my 22, but had to put the correct ring gear on the flywheel so that it matched the modern starter gear.
Good luck and keep us posted on your search. Grant.
Sat, Oct 12, 2024 10:16 PM
Reply to GrantJ:
Here is the 736D Build Sheet.
The hardest part would be finding the 1850844 Drive Housing.
 [attachment=77856]736D Starter Build.jpg[/attachment]
Sun, Oct 13, 2024 11:41 PM
Thank you received: 77
Which catalog number / grouping (truck, car/passenger, etc.) is that page from, OM?
Mon, Oct 14, 2024 5:16 AM
Besides the info in the header it's from my Delco Remy Service Parts catalog, about 8" thick in screw post binder. The kind you used to see on the counter of old time parts departments.
Mon, Oct 14, 2024 6:08 AM
The 39MT starter in SAE #3 arrangement could possibly work but you would need to change to a 10 tooth pinion which I believe is available ( straight tooth in this application).
I haven't done it so you would be beta tester.
Mon, Oct 14, 2024 7:14 AM
cr
Send a private message to cr
Thank you received: 25
There was an article a while back on the conversation process, including changing over or adding the ring gear.
https://www.acmoc.org/bb/discussion-d72/15214-chapter-9-caterpillar-twenty-two-electric-start-conversion?start=0
Mon, Oct 14, 2024 10:30 AM
naylorbros
Thank you received: 31
Reply to cr:
OM. I bought one of those 8” thick Delco books just for that page. There is a lt of interesting stuff in that book
Mon, Oct 14, 2024 11:11 AM
