What to do with my pony motor 54 d47u
Coachmiami
Send a private message to Coachmiami
I am rebuilding a 54 D47U and removed the pony motor and parts as I am replacing with a starter and 24v batteries. The previous owner (my neighbor) says it started two years ago but is not free right now. Is it worth me putting time into it and free it up or is valuable to someone as is? I am in Peterstown WV and open to suggestions! Thanks!
Sun, Oct 4, 2026 4:11 PM
Coachmiami
Well... I guess no answer is as good as an answer! I think maybe take off the heads and see if I can free it up and go from there.
Mon, Oct 5, 2026 11:13 AM
jbernd56
Thank you received: 6
Dont let the deafening sound of crickets get you down. Sometimes response is slow. Somebody somewhere is needing/looking for what you have. Sometimes it is a matter of just how far you are willing to travel for stuff.
If you are into you tube, Check out Squatch 253. He has several very good videos on rebuilding pony motors. It will give you an idea if you want to spend the time and $$$ rebuilding a pony motor.
Mon, Oct 5, 2026 1:23 PM
Thank you received: 78
Apologies! If you don't intend to use it yourself, then the most you probably want to do is see if you can free it up, and removing the heads and using some gentle persuasion with a block of wood and a hammer could help. You'd want to alternate between the sides so you're not damaging the rods and bearings too much. If you have time on your side, you can also re-install the heads and fill the bores up with diesel and oil (some use ATF and add some acetone) and let it soak first. Alternatively, you can stand the engine on one side so a cylinder is facing upwards, pour some diesel in there, and set it on fire. The heat will quite often break any bonds. I've done that before with good results. Then optionally flip it over and do the same on the other side. You can also check if there is any rotation, no matter how miniscule, in the crank to verify that it's not seized. Let us know how you get on
Mon, Oct 5, 2026 1:26 PM
Coachmiami
Much appreciated. Makes me think I should spray some starting fluid in there and light it off! ;-0 That ought to do it. I have so much work on the dozer itself I am really not into rebuilding a pony motor I am not going to use.
I have the much of the motor auxiliary stuff off and down to the radiator and head- removed skid plate, manifolds, generator, pony, what was left of the seat and fuel tank. Now just trying to clean up decades of oil, grease and dirt so I can get a bit of paint and see how all internal parts are.. I'm sure I'll be back soon especially with winter coming and time to work on it inside.
Mon, Oct 5, 2026 6:50 PM
Thank you received: 227
Progress! One bolt at a time, careful with those little pieces, the ones you can misplace so easily (been there too many times! then spend hours chasing through the pile of parts). Please keep us all involved with your progress reports and pictures. RE: starting engine, do not throw it away, if nothing else, put some acetone/ATF in the cylinders, cover the open ports with some "magical" duct tape or even cardboard cereal box "gaskets". Sometime you will find yourself wanting to tinker with it. Do have proper "filter" in the air for those unexpected moments when the language becomes a big overwhelming because of those banged knuckles. -- cts
Mon, Oct 5, 2026 7:28 PM
