What should the clearance be on the outer crank bearings on a Pony motor?
daves2035
Send a private message to daves2035
I Have a D2 5u . Rebuilding the pony motor. Bought new bearings for the outer crankshaft.Going to have crank ground,what should the crank to bearing clearance be?
Sat, Jul 30, 2011 5:52 AM
Here are the complete pony specs:
Sat, Jul 30, 2011 6:56 AM
Thank you received: 22
Dave,
did you buy standard size bearings from Cat or someone else, and if you don't mind, let me know the cost - thanks!
Neil.
Sat, Jul 30, 2011 8:46 AM
