What should the clearance be on the outer crank bearings on a Pony motor?
daves2035
Send a private message to daves2035
I Have a D2 5u . Rebuilding the pony motor. Bought new bearings for the outer crankshaft.Going to have crank ground,what should the crank to bearing clearance be.
Sat, Jul 30, 2011 5:52 AM
grab the scan below while it is up. It looks a bit blurry but I believe it prints OK, please let me know and I will try and scan it again, this was a high res. scan so I do not know what else I can do to improve it.
Clearance front and rear brgs. is 0.005"-0.0085" with a max allowable of 0.015"
Standard front and rear journal dia. is 1.8120"-1.8125"
Sat, Jul 30, 2011 7:28 AM
