What model grader am I looking at here?
Showing 1 to 7 of 7 results
Mangoman
Send a private message to Mangoman
Hi folks,
I have a good friend that looked at an old grader the other day. I haven't seen one like it before but I'm no expert by any stretch. It somewhat looks like a No.11 but the drawbar is channel and looks older. It also has a D4400 rather than the D6600. The motor unit looks to be a different shade of yellow. Any chance the D4400 was retrofitted? It just looks a little unfinished how it is installed. When I did a little research, I found out about a No.10 Tandem Diesel grader. Could this be one of them? Thanks friends.
Mangoman
Wed, Aug 18, 2021 8:13 PM
The #10 Auto Patrol, tandem, 1937 - 39 uses the D4400.
Wed, Aug 18, 2021 9:50 PM
Eds-oldiron
Send a private message to Eds-oldiron
The serial number is stamped on the brass tag above the left front wheel in your photo, on the web of the frame channel. That will ID it.
Wed, Aug 18, 2021 9:52 PM
Mangoman
Reply to Eds-oldiron:
Yes Eds, I will refer my friend to check. He didnt get that info but that will positively identify what we are looking at. I just thought I might get some preliminary info from more knowledgeable folks. Thanks
Wed, Aug 18, 2021 10:22 PM
bursitis
Reply to Mangoman:
interesting fuel filter arrangement.
Wed, Aug 18, 2021 11:51 PM
Reply to bursitis:
Should be a 2Kxxxx s/n, same engine as RD4.
Thu, Aug 19, 2021 1:41 AM
Thank you received: 95
the fuel filter is the standard edge type brass plate stacked canister that are a cleanable elephant strainer of the day---see scan below from a D4400/D4 fuel system.
Thu, Aug 19, 2021 7:02 AM
Mangoman
So, my friend got back out to look at the grader. From what I can read it says 9F1616TS. What does TS mean if that is what I am reading? From what I can see 9F means Auto Patrol No.10 It also looks like there were No.10 graders with the D6100 3cyl as well as the D4400? Anyone have a better idea of the actual year of this thing, and also about the "TS"? Thanks!
Wed, Sep 1, 2021 7:28 AM
