what machines have the D343 engines
Showing 1 to 10 of 10 results
IHIAM
Send a private message to IHIAM
The one a friend has is out of a 613B and he's wondering what other machines this engine could help save as he's a collector and wants to see it go to good use. IHIAM
Sat, Mar 1, 2008 4:59 AM
SJ
Send a private message to SJ
I don,t think the 613 had the D343 but maybe he got the numbers turned around as the 631 had it and the most common machines using it was the 87A 988 loader and the 38K- 983 loader and also the 657 scraper rear engine used it and also the 825 & 826 compactors also the 666 scraper used it too in the rear.These were tractors in their early years of production that used it. Also it was used as an over the road truck engine called a 1693 but had lots of housing changes to cut down on weight but the basic engine was still the D343. Off hand that,s the most places it was used but was used in a couple other applications esp. for industrial useage.
Sat, Mar 1, 2008 6:46 AM
bob
Send a private message to bob
Reply to SJ:
I think the 16 motor grader too. When swaping into other machines you should use fuel system from original machine.
Later Bob
Sat, Mar 1, 2008 9:45 AM
moonshadows
Send a private message to moonshadows
Reply to bob:
Later Bob
thanks for the information iam the one with this engine and thanks to IHIAM for posting this question i just got registered i dont know much about this piece of equipment but would hate to scrap any good parts !!! here is a picture for help iding it
Sat, Mar 1, 2008 9:54 AM
rusted
Send a private message to rusted
Reply to moonshadows:
That looks like the carcass of a 631B to me......oops..you already said that... sort of.
Sat, Mar 1, 2008 9:56 AM
moonshadows
Reply to rusted:
yes i transposed the numbers earlier it is a 631b NOT a 613b 😕
Sat, Mar 1, 2008 10:16 AM
moonshadows
Reply to SJ:
what hp would that engine be rated at ?? how much did the complete tractor weigh ??
Sat, Mar 1, 2008 10:18 AM
Thank you received: 60
Depending on the serial number they ranged from 335hp to 360hp and topped out at 400hp during their 1962 to 1970 production. The whole rig weighed about 70,000 lbs.
Sat, Mar 1, 2008 11:52 AM
SJ
Yes Bob the #16 grader used it too as I forgot about it using it.
Sat, Mar 1, 2008 7:49 PM
Warren
Send a private message to Warren
Reply to SJ:
The 983 track loader used them too. God what a beast they were😄
Warren
Sat, Mar 1, 2008 8:29 PM
moonshadows
Reply to Warren:
it seems there are enough applications i might find a good home for it thanks for all the info --scott
Sat, Mar 1, 2008 11:28 PM
| Kingaroy, Queensland
