What is the trick for removing steering brake pins on Cat D7-3T
716thMP
Send a private message to 716thMP
Caterpillar shop manual says,"remove pins". I would like to know how. The pins have shoulders with washers and the fixture holds the top brake shoe in downward facing slots and the bottom brake pad pin goes in a upward facing slots.
Wed, Dec 20, 2023 8:49 AM
clayton
Thank you received: 25
If I’m understanding you correctly I believe you have to unscrew the adjustment nut completely off after that it should give you room to remove the pins. Someone else with more experience will chime in Clayton.
Wed, Dec 20, 2023 10:44 AM
josh
Thank you received: 14
From the D7 Servicemen's Reference book.
Wed, Dec 20, 2023 11:17 AM
