What is the difference ?
HOLLANDCAT
Send a private message to HOLLANDCAT
I have a to order New links for a D7 4T for the main clutch .
Now i have a quote on new ones , but there are 2 different types , plastic or fiber .
Who can tell me what would be the difference?
Thank you , Gilbert
Sat, Jan 7, 2017 9:27 AM
catskinner
Hello,
Fiber would be like the original links. I've never seen or heard of plastic clutch links. catskinner
Sat, Jan 7, 2017 10:30 AM
caterpillar13
Reply to catskinner:
Hello,
i have plastic in my d8 1h and fiber in the other d8 1h, i think the plastic is better as it wont rot as fast as the fiber and the plastic were cheaper ,, just my 2 cents ,,
Sat, Jan 7, 2017 12:02 PM
Andrew
Reply to caterpillar13:
If a link has broken best to replace the whole lot and I dont think it is important which type you use.
More important to check the engine alignment to the transmission.
Sat, Jan 7, 2017 1:08 PM
Bruce P
Thank you received: 33
Reply to Andrew:
[quote="Andrew"]If a link has broken best to replace the whole lot and I dont think it is important which type you use.
More important to check the engine alignment to the transmission.[/quote]
Totally agree, my 7M was badly out of alignment and was a real bearcat getting it right, but worth it.
BP
Sat, Jan 7, 2017 9:31 PM
HOLLANDCAT
Reply to Bruce P:
BP
I wil forward this to the D7 owner , he took the engine out because there were several issues .
Starting gear is very bad , the seal from the drive shaft from the gearbox is leaking and the gearbox lock plungers were broken and bend .
Thank you for your advice . About the engine alignment that is the important thing now .
Gilbert
Mon, Jan 9, 2017 4:07 AM
| Kingaroy, Queensland
