What engine has this CAT 933F
Showing 1 to 7 of 7 results
Nico Ensink
Send a private message to Nico Ensink
Hello You all,
A friend of mine has bought a CAT 933F with serial 42A5436.
We now wonder what engine this machine has?
The tag on the engine says Austauschmotor which is German for replacement engine.
We find it is either a CAT D311 or a D320T.
It does not look like the D311 from the D2 5U but looks much more like the D320T I have in my 922A except for the turbo.
It has a compact ( scroll) fuel injection pump.
Maybe it is a new D311 but we cannot find any data on this engine.
We are looking for common data like valve clearance mainly an other useful maintenance data.
Can anyone shed some light on this?
Thanks,
Nico
Fri, Jan 27, 2012 4:05 PM
rusted
Send a private message to rusted
Hello Nico,
With that serial number it should indeed have been a D311 originally, according to my book the F series became the G series at serial #6164 when the D320T replaced the D311. If the engine was replaced it would seem logical to put a D320 in it...yet all D320's were turbocharged. :confused2:
Fri, Jan 27, 2012 5:57 PM
PeterS
Send a private message to PeterS
Reply to rusted:
Hello Nico,
Hello Nico, I had a machine that was a 42A5212, very close to yours. Mine was a 1964 and did have a D311 engine just as rusted said. It is a different D311 than the D2's. I am not sure why they made the designation the same. I have the book, just have to get it later today with the data. I have a few NOS rebuild parts if you need them. If there are other specs you need, let me know and I will get those as well.
Best of luch, Peter.
Fri, Jan 27, 2012 6:39 PM
farmks
Send a private message to farmks
Reply to PeterS:
The 933f did not come with turbo. The 933G had the turbo, wider track spacing and other changes. I have both. The 933f is for parts to keep 933g going. Take the covers off the the track springs you will probably find the track support broken. Better grease the front ujoints on the hydraulic pump drive. They are hard to get to and you will not find a replacement part anywhere. Ebay has shop manuals and parts books. Any other questions, just ask. I have learned the hard way.
John
Sun, Jan 29, 2012 11:40 PM
Thank you received: 60
Reply to farmks:
John
Saw your comment on the u-joints.
Here is some aftermarket info that might help....
CR Services u-joint #UJ870 (outside lock rings)
4-plain round ends
7/8" dia. bearing od
overall width 2-1/2"
Original Equipment supplier - Rockwell L10N
This is for the 42A's
11A's to 11A3653 use the same size but lock rings are on the inside. (#UJ861)
Mon, Jan 30, 2012 12:31 AM
Nico Ensink
4-plain round ends
Hello All,
Thanks for your answers.
I understand it is a different engine than th earlier D311 from D2 5U.
The engine looks very similar withmy CAT D320 apart of the turbo which is absent on this one.
As it is also a 4"x 5"engine, I assume valve lash is simi;ar to my D320: 0.015 for the inlet and 0.025 for the outlet valves measured with engine hot.
Please confirm?
Thanks again,
Nico
Mon, Jan 30, 2012 11:03 PM
Reply to Nico Ensink:
Hello All,
Please confirm?
Thanks again,
Nico
You are correct. Valve lash is the same for the second generation D311.
Mon, Jan 30, 2012 11:19 PM
PeterS
Nico, I admit that I express my good intentions must faster than my actions can keep up, but I scanned the specs pages from the Cat manual for you. Email me and I will send them to you. That way you should have most everything that yoou may need for the engine.
Take care, Peter.
pureenduro at msn dot com
Sat, Feb 4, 2012 2:51 AM
| Kingaroy, Queensland
