what does a d7 weight
Showing 1 to 6 of 6 results
deetwocat
Send a private message to deetwocat
my buddy was over the outher day and we were talking about what the d7 tha has been sitting in my back yard weight dont worry i would never send it for scrap. That being said when scrap was high i turned down $2000 .
Fri, Jan 8, 2010 4:55 AM
bruce oz
Thank you received: 23
hello deetwocat ,which model do you have ? ,bruce oz
Fri, Jan 8, 2010 5:57 AM
deetwocat
Reply to bruce oz:
i cant seem to see the serial tag on the engine on the back is a winch covering that tag i was told it from the old owner that it is about a late fiftys modle it has a hand clutch that i think would be dry. i think it is to far gone for repair it has no blade but does have hyd. cylinders thanks.
Fri, Jan 8, 2010 10:36 AM
Billy-
Send a private message to Billy-
Reply to deetwocat:
Have a look at the S/N above the pony motor transmission. If you cant find that either just post a pic and we should be able to workout what it is. A late 50's model would make a D7 17A [ "C" or "D" series ].
D7C weighs 26930lbs bare operating weight.
D7D weighs 27230lbs bare operating weight.
Cheers
Billy
Fri, Jan 8, 2010 10:43 AM
catman580
Send a private message to catman580
Reply to Billy-:
Cheers
Billy
I have a D7 17A 18,000 serial # it is a 1961 year with a straight cable blade and i think it is a #25 ccu not sure about the unit . Would any know what the total of tractor , blade and ccu ? 😊
Fri, Jan 8, 2010 11:08 AM
Billy-
Reply to catman580:
Catman580
Tractor wieghs - 27230lbs
#25 Cable Control Unit - 2070 lbs
Cat 7S Blade - 5080lbs
That comes to a total of 34380lbs. If it has belly gaurd and or canopy you need to add a little more for them.
note, these are all approx fiqures
Fri, Jan 8, 2010 12:01 PM
catman580
Reply to Billy-:
Catman580
Thanks Billy , knowing the proper weight is good to know . 😊
Fri, Jan 8, 2010 10:46 PM
| Kingaroy, Queensland
