what do you use in your diesel for lubricity
captainhowdy
Send a private message to captainhowdy
just wondering if i should use an additive in my 1953 D4? i have heard of using ATF or just plain old 30 engine oil. powerservice etc etc etc.
Sun, Jul 16, 2017 11:38 PM
Stanadyne has a lube formula.
Sun, Jul 16, 2017 11:57 PM
ol Grump
Two stroke oil works well too.
Mon, Jul 17, 2017 5:58 PM
ronm
Reply to ol Grump:
Check with your fuel supplier. Most have dealt with the lubricity problem that ULSD had at first. I was filling the pickup one day at the CO-OP & the guy that drives the fuel truck saw me adding some fuel conditioner...he came over & said "You know, we put that in all the diesel now anyway".
But, a dose of ATF will help any Diesel system.
Be careful adding it to a road vehicle, the fuel nazis will see red & bust you for running off-road fuel.
Mon, Jul 17, 2017 7:41 PM
boaterri
Send a private message to boaterri
Reply to ronm:
Howe's Diesel Treat works very well and helps with water in the fuel.
Rick
Mon, Jul 17, 2017 10:29 PM
Oil Slick
Reply to boaterri:
Rick
I've always used two stroke. No proof on performance but makes sense to me.
Local fuel injection shop says "using oil for an atitives make the diesel harder to combust and I should buy his fuel additive that cleans, lubes, and burns easier. I still use 2 stroke though.
Tue, Jul 18, 2017 6:19 AM
oldbeek
Reply to Oil Slick:
California diesel is drier yet. I use 2 stroke oil from Walmart. I use it in my dodge, Cummins. Increases cetane a bit and improves milage a bit. I qt to 35 gallons.
Tue, Jul 18, 2017 11:44 AM
smitrotterdam
Send a private message to smitrotterdam
Reply to oldbeek:
Ordinary two stroke oil regularly and Seafoam occasionally.
Wed, Jul 19, 2017 7:03 AM
hotrodwelder1
Send a private message to hotrodwelder1
Reply to smitrotterdam:
ATF in the fuel tank works well and don't forget to add ZDDP to the engine oil, due to the low zinc content in engine oils these days..
Sun, Jul 23, 2017 4:10 AM
| Kingaroy, Queensland
