What do you see?
What do you see?
Showing 1 to 7 of 7 results
sawatzky1
Send a private message to sawatzky1
Photo courtesy HarleyEarl "I LOve Automobiles"
Fri, Sep 11, 2015 6:47 AM
As for the Cat, looks like an old slide shifter D8.
Fri, Sep 11, 2015 7:08 AM
The Cat looks like a Diesel Fifty.
Fri, Sep 11, 2015 7:20 AM
Correction I think a Diesel Forty. Looks to be a three cylinder.
Fri, Sep 11, 2015 7:27 AM
Sasquatch
Thank you received: 5
Yep, definitely a 3 cylinder with the water pump tight up against the pony and the distinct 3-ported exhaust manifold. Love the old split front idlers on it too!
Fri, Sep 11, 2015 7:37 AM
daron
Reply to Sasquatch:
https://en.wikipedia.org/wiki/Honolulu_Clipper
Daron
Fri, Sep 11, 2015 9:26 AM
Wombat
Donor
Diesel 35, air cleaner for pilot motor mounted near diesel tank.
Fri, Sep 11, 2015 3:55 PM
naylorbros
Thank you received: 31
Reply to Wombat:
As it sits it is a Diesel 40 unless a field change up kit has been installed. The Diesel 40 also used the air cleaner mounded to the diesel engine intake manifold like the 35 but if you look closely in this picture the carburetor is a Zenith not the Ensign used on the Diesel 35s and early Diesel 40s. There was a feild change up kit to change the Ensign to the Zenith and used the same air cleaner. I do not have my parts books here but if I remember the late Diesel 40s used the air cleaner mounted on top of the starting engine carb.
Fri, Sep 11, 2015 9:28 PM
