What Brass plates originally came with 22's and R2 5E's?
nw4evr
Send a private message to nw4evr
I have a 22- 1J and an R2 5E, and am getting to the point of needing to find out what is originally supposed to be on these as far as brass plates, so i can consider finding and buying them, and hopefully installing them!
I have seen numerous photos of differing vintage 22s (5 E close up photos are a bit harder to find )and some have a plate behind the seat, some don't... ( one of mine must have had at least one, cuz there were tiny holes, i think for the patent number plate) Is anyone an authority on what plates should go where on the machines I have???
Out of Three machines i have, all i have is one plate total, ( on the steer clutch adjust cover )with the shift pattern and some text on what you should or should not do with the driveline... and it is kinda worn off and hard to read,,, any advice also on how to make this more legible??? I was thinking of taking it to a place that makes bowling trophies and such to see what they think if they might restore it , or does someone have a better idea of how to DIY??
Should there be any plates on the seat sides ?( perhaps a dealer plate?), again i have evidence of tiny holes...
Also need one S/N plate (made up new by someone out there, ideas?????? ) for the rear trans housing, which also is missing, but the tiny holes are there...
Project machines are R2- 5E 3542SP ,,, and 22- 1J 1098WSP
Thanks for any guidance, gotta start up the construction season next week, so the Cat restorations will have to "simmer" but i can look for parts and advice at nights from the motel.. or Call if you'd rather... Dave Pickhardt 920-210-2875
R2 5E 3542 SP, 22 2F, 22 1J
Wed, Mar 30, 2011 6:07 AM
kiwicats
Send a private message to kiwicats
send me an email to [email protected] as i can forward you a contact.
peter
2 Ton
10
15
22 (2f,1j)
R4
D2 (3j,5j,4u,5u)
D4 (4g,7j,2t,5t,6u,7u)
Diesel 35
D8 (8r)
Thu, Mar 31, 2011 12:52 AM
brewzer
Reply to kiwicats:
peter
2 pictures of original 22 tags. The one on the back of the seat ( painted over) is a 2f or early 1j tag and made of brass. At some time unknown to me the late 1j series started placing the tag on the seat side. The tag is no longer brass. Not sure if it is tin or something else.
Sat, Apr 2, 2011 8:52 AM
nw4evr
Reply to brewzer:
wally you have the info i needed, will call you sometime. now i know more than i did, what are the sn s of the machines you pictured?? if you would be so kind.... Dave P
Tue, Apr 5, 2011 9:18 AM
brewzer
Reply to nw4evr:
The tag on the back of the seat-2F5488. The tag on the side of the seat-1J4849. For your information 1J256 has the tag on the back of the seat. - Wally
Wed, Apr 6, 2011 9:07 AM
nw4evr
Reply to brewzer:
will research dates of manufacture of these s/n ' s... i have this info at home .. and will have a better idea of what should go on mine from this info.. looks like mine should have something on the seat back of the 5E.. you have been a huge help again!!!.. still looking for a someone who may sell me a seat back plate.. Dave
Wed, Apr 6, 2011 9:37 AM
