What are these attachments?
Thank you received: 226
Thu, Nov 12, 2026 5:41 PM
Thu, Nov 12, 2026 5:42 PM
Remember when this tractor was at work - might be a clue as to why these were installed.
Thu, Nov 12, 2026 5:44 PM
jbernd56
Thank you received: 6
Looks like rifle sights. You could aim at a fence post, tree or something on the other side of the field or down the row. Somebody was a lot concerned about making straight passes at something! The bell could have been for somebody on a grader or land plane or something to signal the driver when to stop, turn, etc.
Fri, Nov 13, 2026 2:12 PM
Thank you received: 54
Reply to jbernd56:
i think you may be right.
sight to align the work row and a bell to communicate with the driver.
Sun, Nov 15, 2026 7:56 AM
"Sights" are a correct response. The bell was used to signal the Catskinner from either the header tender or the separator man on the combine. There was very little the catskinner could see or feel about the combines operation. Communications were vital. - cts
Sun, Nov 15, 2026 4:07 PM
Thank you received: 140
Hi, cts.
There was similar 'bell' arrangement on the Cat elevating graders consisting of a 'dinger' and a spare disksuitably disposed to each other. I can even remember the 'bell code' which was written in paint on the bell disk of a Cat #48 elevating grader:
1 ding = Stop. 2 dings = Turn left. 3 dings = Turn right. 4 dings = Go home.
Funny thing is, I don't remember there being a code for "Start" or "Go"
Just somebody else's 0.02.
Sun, Nov 15, 2026 7:17 PM
deas
it was probably a yelled, "lets go what are you bloody waitin for" at idle you would be able to hear
Mon, Nov 16, 2026 12:05 AM
Hi, tk88.
I watched them at work and it usually seemed to be either a slight wave or a thumb-zup - 'coz the tractor operator could be looking back at the grader then rather than forward to see what he was running into or which 'adventurous' spectator he was about to run over.
NO bell code.
Mon, Nov 16, 2026 12:52 AM
