What are the symptoms of a failing condenser?
Showing 1 to 10 of 13 results
Bill Glenn
Thank you received: 6
What are the symptoms of a failing condenser? The pony motor on the 955 12H has been missing worse & worse… Just wondering if the condenser could be the culprit. Also, here is a picture of Rodger the Dachshund & I getting ready to skid some firewood on said machine.
Sat, May 2, 2020 12:41 AM
Norm R2,22
Send a private message to Norm R2,22
Usually the engine will run rough, if at all. Back firing as un-burned fuel from the mis-fires in the exhaust catch. Most people suspect carburetor problems. Thus the saying, "90% of carburetor problems are electrical".
Sat, May 2, 2020 1:46 AM
Thank you received: 78
Reply to Norm R2,22:
They also might start ok cold then as they heat up become less reliable, and so "won't start when hot". Might also get a yellowish spark instead of a bright blue spark.
Sat, May 2, 2020 2:44 AM
Mike Meyer
Do they burn the points too?
Sat, May 2, 2020 4:47 AM
Bill Glenn
I have a white spark now... what does that mean...?
Sat, May 2, 2020 7:49 AM
Bill Glenn
I have a white spark now - what does that mean?
Sat, May 2, 2020 7:50 AM
Bill Glenn
Reply to Bill Glenn:
Where can I get said condenser?
Cat should have it. Have a part #?
Sat, May 2, 2020 8:27 AM
Caterpillar should have it or any of the magneto shops can get them if they don’t have it in stock. You can also test with a multimeter to see if they’re shorted or open. I think most ignition capacitors are about 0.3 microfarads.
Before I took the condenser out I would clean the points with an emery board and re check the gap. That takes very little time and can fix problems immediately.........or not and then you move on to something else.
Sat, May 2, 2020 8:33 AM
kittyman1
yes this has been my experience exactly....after a few minutes it starts missing...acting crazy...maybe even quitting...and no start...:tape:
-almost exactly the same as some electronic modules...
Sat, May 2, 2020 8:57 AM
Reply to kittyman1:
Normally I would add in to check and or lubricate the pivot shaft on the points. One time mine was dry and causing the points to stick occasionally. Mine starts right up and runs fine unloaded but I noticed last year that it was missing under load. No amount of choke helped it so I am thinking I need to get the hood off to play around in the Magneto.
Sat, May 2, 2020 7:09 PM
