What are 2S 4442 injector nozzles??
Showing 1 to 10 of 19 results
Rd6 plower
Send a private message to Rd6 plower
Found them in a D6 9U. After market maybe?
Tue, Mar 2, 2010 1:32 AM
gemdozer
These injector are use on many machines like 955h,944 loader and more
Tue, Mar 2, 2010 2:34 AM
Rd6 plower
Reply to gemdozer:
I also relized that it has a rack stop clip on it. Are those injectors any good? And are they counter bored. I already swaped them out for 9F4113 counter bored injecters and reset the rack at .215.😄 But which is better the other ones or the 9F4113's?
Tue, Mar 2, 2010 3:10 AM
Thank you received: 31
Reply to Rd6 plower:
here are some scans of nozzle conversions I used at The Dealer.
Second chart gives Nozzle P/No and the Valve Service Group they come with, this is the only chart I know of to convert either way.
Hope this answers some of the query.
Tue, Mar 2, 2010 5:55 AM
Thank you received: 46
Reply to edb:
The 9F4113, 6H3364 and 2S4442 are all good numbers and all counterbored nozzles.
What are you doing with a stop clip on the 9U rack??? That's usually done only on the DW10's or special applications that also involves the special governor.
Seems like somebody's been tinkering. The clip that matches the later nozzles is a 9F4476.
Tue, Mar 2, 2010 7:14 AM
Rd6 plower
This is the first time we've cracked the governer open since we've owned the tractor which is about 23 years but we did put a new block, head, pistons, sleeves, chrome rings, water pump, raidiator, pony has been gone through and it has a new block too. I have no idea why there is a rack stop clip on it but it's there and it did bottom out with the old rack setting witch was .330!!!!😮 I don't know why it never threw black smoke😕 it's a 1948 9U. The governer did does a throbing when at full throtle with no load. So I don't know if I changed anything hp wise? But it does throw a little black smoke under a load now though it never has before I changed the injectors and rack setting. It does seem to be louder though. I have no idea what's better for it the way it was or the way it is now.
Tue, Mar 2, 2010 9:02 AM
What is the governor group number?
Tue, Mar 2, 2010 11:26 AM
Rd6 plower
It's the normal 9U guts and wieghts , spring but just a clip in there.
Kinda off topic but how come it seems like the d318's have a smaller rack setting then the D311's and the very last d2's had a rack setting of .365? Why did they do that? They are smaller bore? Just somthing that I've been thinking about.
Wed, Mar 3, 2010 2:47 PM
Hi Rd6 plower,
the D2 injection pump has smaller Diameter plungers and barrels, so, it needs a useful rack setting to suit the lower volume of output of the pumps. This is done to keep the governor operation within useable limits. If we had the same sized plumps on all engines the small engine governors could not hope to control the engine with such small governor movements, they would be unstable in RPM's etc.
When all is said and done the engines have a maximum designed Brake Mean Effective Pressure --average maximum cylinder pressure -- and regardless of engine speed this cannot be exceeded.
A check of the rack settings for each engine family at the given engine working speed (Full Load RPMs) will show that as the engine's working speed increases so does the rack setting, BUT, the BMEP remains constant at all these various working RPM's due to the changes in the Rack Settings --they increase as do the working RPM's and consequently so does the HP output of the engine at these higher working speeds.
Sorry if this is a bit deep, there are many confusing things to the layman about Rack Settings, RPM's and timing on Diesel engines among other things.
Hope this helps answer your query on Rack Settings versus engine size.
Wed, Mar 3, 2010 4:09 PM
catsilver
Reply to edb:
Hi Rd6 plower,
If those 2S4442 injectors are intended for use with turbocharged 955H and 944 engines, they are unsuitable for naturally aspirated engines and I have known their incorrect use on N/A engines cause a piston siezure, so be sure only to use injector nozzles which match your serial number.
Wed, Mar 3, 2010 10:25 PM
Reply to edb:
Hi Rd6 plower,
Governor internals may look the same but they have differences...in weights, springs, stages, etc.
The extreme setting on the D318 (8T/80C graders & DW10-1V) is a rack setting of 0.465 in. on units without torque spring.
Wed, Mar 3, 2010 10:31 PM
