What a difference 2 weeks make!
Showing 1 to 10 of 11 results
d4angelo
Thank you received: 6
New clutch has been installed and I was able to play with it today, [attachment=74483]IMG_2937.jpg[/attachment] disking about 10 acres. Juiceman isn't the only guy around here that gets to have some fun.
Sun, Dec 10, 2023 7:30 AM
Thank you received: 258
Good job. Get out there and shine up the pads as well as those blades.Where are the action photos of you, Crawler$$$ and Jan swinging the hammer on your D2?
Like some say, photographs, or it never happened... JM
Sun, Dec 10, 2023 8:25 AM
d4angelo
Crawler $$$$ is in the witness protection program.
Sun, Dec 10, 2023 10:04 AM
mog5858
Reply to d4angelo:
glad too see you had nice weather to make it a quick fix. I glad it passed the testing afterwards looks like fun
Sun, Dec 10, 2023 8:33 PM
Peter C
Send a private message to Peter C
Reply to mog5858:
Way to go, Angelo. I’m envious of your weather by the way. Yesterday I was working on my 22 in the snow trying to drain the bevel gear case but it had water in it that had frozen solid.
Pete
Mon, Dec 11, 2023 4:55 AM
d4angelo
Reply to Peter C:
Pete
Thanks Pete, it was a big job for me because I have never needed to "split" my tractor before. The key is to have the proper lifting tools and wood cribbing. The weather was 80 degrees when I replaced the clutch and a very nice 75 degrees when I was disking. It ran like a champ yesterday, i just hope the clutch does not destroy itself again!
Mon, Dec 11, 2023 5:14 AM
Making my own fun today at mom’s downtown farm.
My poor D4E needed a jump start from being idle so long. That’s my pet peeve. Jump starts are a no no here.
A friend and new member has been diligently working on his new to him 5U. I will allow him to chime in on his new found fun.
The doggone 62 series was ready to work though! JM
Mon, Dec 11, 2023 7:08 AM
Thank you received: 61
Look at it this way Angelo, the next time the clutch disk teeth shed themselves, you'll know exactly what to do, all the fasteners will loosen easily, and you'll be in and out in half the time : )
Mon, Dec 11, 2023 8:04 PM
8C 361
Thank you received: 12
A solar panel is the solution to your need for a jump start.
Mon, Dec 11, 2023 8:42 PM
d4angelo
Hey Neil, the next time it happens, I'm going to fly you out here to help me with the project!
Tue, Dec 12, 2023 1:02 AM
Reply to d4angelo:
so long as you have shade and some cold beverages, I'm in! : )
Tue, Dec 12, 2023 10:21 AM
