Wet Starter Pony Motor D7E 48A 160HP?
catdozer876
Send a private message to catdozer876
Hello, I am wondering if the pony motor starter on a D7E 48A is sealed and considered to be a wet starter? If I have it overhauled does in need to be sealed from oils that come from the ring gear/bell housing of the pony motor? Pony Motor is a 12 volt Delco # 1107213 D7E 8, (this is stamped in the Delco Tag). Thank You.
Tue, Dec 13, 2016 2:33 AM
Thank you received: 60
The only seal involved is part of the front motor bearing assembly and would be replaced as part of a standard rebuild.
There is also a mounting flange gasket.
Tue, Dec 13, 2016 3:36 AM
catdozer876
[quote="Old Magnet"]The only seal involved is part of the front motor bearing assembly and would be replaced as part of a standard rebuild.
There is also a mounting flange gasket.[/quote]
Thank You Old Magnet! Have the pony starter motor out and am cleaning it up and noticed the ring gear is in oil! One step at a time.
Tue, Dec 13, 2016 5:27 AM
Reply to catdozer876:
Yes, that model starting engine is an oil clutch version.
Tue, Dec 13, 2016 6:30 AM
gemdozer
Thank you received: 24
The starting engine motor and cluch have the same level oil and use 1 1/4 qt in
Tue, Dec 13, 2016 8:35 PM
gemdozer
Reply to gemdozer:
I make a mistake the poney transmission use 1 1/4 qt oil and motor and cluch ass use 4 1/2 qt oil in
Tue, Dec 13, 2016 8:56 PM
| Kingaroy, Queensland
