Weight on 2-ton
Weight on 2-ton
Showing 1 to 6 of 6 results
2-22dud
Send a private message to 2-22dud
Whats the weight on a 2-ton?
Tue, May 20, 2008 2:05 AM
chugwater crawlers
I thought it was supposed to weigh 2 tons?
Tue, May 20, 2008 10:13 AM
ibrich
Send a private message to ibrich
Reply to chugwater crawlers:
I am sure there are plenty of people on this forum that know the answer to your question. I did a quick search on the Internet and came up with this site:
http://www.tractordata.com/td/td931.html
Which says the weight is 2500 lbs.
Good luck,
Rich
Tue, May 20, 2008 10:31 AM
ibrich
Reply to ibrich:
Good luck,
Rich
As I said in the last post I did a search on the net for info on 2-tons. After I posted that message I continued to look at the Google hits. Here is one that some of you might be interested in:
http://cgi.ebay.com/Antique-1927-Caterpillar-2-Ton-Crawler-Dozer-Grader_W0QQitemZ120263428052QQihZ002QQcategoryZ99995QQcmdZViewItem
It is a 2-ton plus a pull grader for the price of $12.5k. There are some good looking pictures. BTW, I have nothing to do with the seller. I sort of wish I did, if the seller was the person who did the restoration.
Rich
Tue, May 20, 2008 10:58 AM
ibrich
Reply to ibrich:
Rich
One last message and I will shut up for tonight. As I continued to check other sites I found one saying the 2 ton weight was more than 2500 which now that I think about it is way too light. Quote from the second site,
"OVERALL WEIGHT * Standard (with operator and fuel tank filled) - 9082 lbs."
Perhaps it would be best if someone with knowledge of the tractor posts a reply.
Sorry about the misinformation,
Rich
Tue, May 20, 2008 11:08 AM
bruce oz
Thank you received: 23
Reply to ibrich:
Rich
hello 2-22dud ,the early holt 2 ton was 4000 pounds(2ton) and the later caterpillar were 2.5 tons ,bruce oz
that wieght is only bare tractor (EX INFO)
Tue, May 20, 2008 2:11 PM
2-22dud
Reply to bruce oz:
Thanks Bruce You coming over sea to the show?
Thu, May 22, 2008 1:48 AM
