Weight of 1960 road grader #12
Showing 1 to 7 of 7 results
clayton
Thank you received: 21
Hello I’m looking at a 1960 road grader #12 curious about the weight, it’s had a 24 volt starter added and pony is still present. 318 engine which has decent power thank you for the info.
Sun, Jan 19, 2025 2:32 AM
D4Jim
Thank you received: 16
What is the serial number? They changed engines around 1960 and if it has the 318 engine it is a 1959 or earlier. Engine in 1960 was D333.
#12 with D318 about 22,400 lb and with D333 about 24,400 lb not including scarifier etc.
Cats Forever
Sun, Jan 19, 2025 5:23 AM
clayton
Reply to D4Jim:
Hello D4Jim sn: 8T17408 so I believe it’s between 1957-1959?
Mon, Jan 20, 2025 2:20 AM
brian18a
Thank you received: 62
Reply to clayton:
1955
Mon, Jan 20, 2025 6:55 AM
clayton
Reply to brian18a:
1955
Well didn’t end up getting this one but will find another thank you for the info.
Mon, Jan 20, 2025 9:55 AM
bernie
Reply to clayton:
212 Motor Grader shipping weight just under 14,000 lbs. with scarifiers adding just under 1,000 pounds.
What am I missing on the weight that makes the #12E 9,000 pounds heavier?
https://www.acmoc.org/library
Tue, Jan 21, 2025 6:31 PM
seyser
Thank you received: 60
Reply to bernie:
The whole frame is larger. Lots of iron there. The 6 cyl engine vs 4 cyl. I believe they share the same cabs but could be wrong.
Tue, Jan 21, 2025 9:52 PM
D4Jim
Reply to seyser:
Seyser is correct in that the 212 is a lot smaller than the #12. The 12 and the 112 are similar except for the engine.
Cats Forever
Wed, Jan 22, 2025 1:15 AM
