weight a motor of d2
Showing 1 to 6 of 6 results
2bluejon
Send a private message to 2bluejon
I was wondering if someone could tell me the weight of the D3400 with the poney and the raiditor hooked on still going to pull one out and decideing what to use thanks
Sat, Mar 28, 2009 10:08 AM
OzDozer
The basic engine with pony weighs 1890lbs. With a radiator attached .. and possibly the clutch as well? - you'd best allow about 2300lbs. The power unit fitted with enclosed clutch, radiator and sheet metal, and mounted on I-beam skids weighs 2770lbs.
Sat, Mar 28, 2009 10:22 AM
abram
Send a private message to abram
Reply to OzDozer:
it's definitely a beast, i just removed mine the pony/rad was off though, i would suggest doing the same.
3J5 D2
Sat, Mar 28, 2009 10:46 AM
hicrop10
Reply to abram:
I removed mine with the rad and hyd control unit all as one.It came out preety easy.The biggest problem I had was to make sure you have the strap or chains place where it will be balanced.Good luck.Mike Durkin
Sat, Mar 28, 2009 7:04 PM
compressor
Send a private message to compressor
Reply to hicrop10:
2blujon,
They are a lot heavier than they look. Hicrop is right getting the right balance would be key here.
Also,keep this in mind.The unit that you are going to lift it out with should be stable enough to deal with the little swings and jiggles that always happen.
It does not take much of a lifting devise to lift a ton and a half,but it does however take a well thought out piece to deal with that same weight while it is dangling percariously just above your toes.
Can you imagine what would happen if something went south with that engine about 3 feet of the ground.
I'm confident that someone would be looking for used motor for a d2.
Good luck Vern.
COMPRESSOR
Sat, Mar 28, 2009 9:31 PM
OzDozer
Reply to compressor:
2blujon,
Good luck Vern.
COMPRESSOR
Remember also, to lift from attachment points that are higher than halfway up the engine .. or you're likely to have it turn turtle, inside any chains or slings you're using.
This is because, if you lift from a low part of the engine, you're below the C of G, and there's more weight above the attachment points than below them.
Any jiggle will almost certainly cause the engine to flip inside the slings or chains. Believe me, I've been there and done that, too .. 😞
Sat, Mar 28, 2009 9:37 PM
SJ
Send a private message to SJ
Reply to OzDozer:
At the dealer shop we had some home made lifters and they were bolted to the valve cover studs coming up and were made from a piece of angle iron and another flat piece welded above the angle iron and had a series of holes drilled in the top flat piece and then a clevis was used in whatever hole you needed to balance it out.We had a big one for D7 & D8s too but it used cable to lift it and clevises on each end and also a series of holes to move the clevis to balance the load.Many of the later tractors had lifting eyes on each end of the block bolted to a couple head bolts so you could use a chain and we had a big heavy chain with a large circle (eye) link in the center and then the ends could be lengthened or shortened up for balance.After you took a few engines out you knowed just about where to position the lifter or chains to balance it out to remove it from the tractor.
Sun, Mar 29, 2009 1:46 AM
