Water leaking around injector
Showing 1 to 10 of 10 results
BOWTIEIH
Send a private message to BOWTIEIH
955 12a3314 I have water leaking around the top of number two injector. I search the site and found this is probably the pre-combustion chamber. My question is what special tools will I need to do this? Is there any tricks that I need to know.
Sun, Nov 15, 2009 9:56 AM
One piece or two piece chamber?
The two piece chamber has the skinny PC chamber and a "retainer" shaped like a doughnut around the top which is removable separately for resealing. There is a set of tools to remove and install the retainer while leaving the chamber screwed into the head. Look down inside the chamber after removing the injector and you should see two size threads inside the opening if it's a 2 piece style.
The one piece chambers have to be completely unscrewed from the head to replace the o-ring around the top. You would want to replace the copper seals at the base of the chamber at the same time. There would be only one thread inside the chamber after you remove the injector. The one piece chambers tend to stick up a bit out of the to head surface compared to the retainer of the 2 piece style.
Sun, Nov 15, 2009 1:07 PM
SJ
Send a private message to SJ
Your leak no doubt is the "O: ring seal around the top of it so yes it will have to be removed to install a new one.Use soap or the white Lubra-Plate grease, nothing with oil base on it so it slips in easily. Coat the seal and the head surface with it.All the years at the Cat dealer we never used anything but the Lubra-Plate. It looks about like Ponds Cold Cream.
Sun, Nov 15, 2009 6:59 PM
chriscokid
Reply to SJ:
SJ, i am glad to see that you know what pond cold cream looks like....haha
Mon, Nov 16, 2009 8:06 AM
SJ
Reply to chriscokid:
Kid, I really meant to say Noxzema but I guess they are about the same looking.This is no joke but a Dr. assistant gave me advice for hemorrhoids (piles) and that is the Noxzema and I have used it for years on mine when they come down and in just a little bit it shrinks them back and takes the smartness (soreness) out of them.
Mon, Nov 16, 2009 6:49 PM
oldparker
Send a private message to oldparker
Reply to SJ:
Hey Bowtieih, in addition to the Noxema, you will need the special tools for removal and re-installation. There has been a great deal of discussion about this subject on this forum lately which you should read up on before you get into the job. There is a set of removal tools for sale on ebay right now. The ebay number is 380234992345. Good luck with your project! John
Mon, Nov 16, 2009 10:05 PM
layal
Send a private message to layal
Reply to oldparker:
i advice you to check this company website they have lot of inflammations about water leaks
http://waterlakecity.com
Sat, Jun 17, 2017 7:46 PM
4x6zh itzik
Send a private message to 4x6zh itzik
Reply to layal:
ATTACH=CONFIG]69062[/ATTACH][attachment=43045]mc3.JPG[/attachment][attachment=43046]mc4.JPG[/attachment][attachment=43047]precom1.jpg[/attachment][attachment=43048]precom3.jpg[/attachment]
STEPHEN
Reply to layal:
[quote="layal"]i advice you to check this company website they have lot of inflammations about water leaks
http://waterlakecity.com[/quote]
Inflammations you say? Better get out the Noxema!
Sun, Jun 18, 2017 12:07 AM
Thank you received: 24
Reply to STEPHEN:
Some of the things that float up to the top from the past.
We lost a lot of useful experience when SJ stopped coming around.
Sun, Jun 18, 2017 12:53 AM
Walt D7-3T
Send a private message to Walt D7-3T
Reply to Ray54:
Hello layal,
Is it possible to provide an English translation on your web site?
Sun, Jun 18, 2017 3:22 AM
Price Tractor Pull
Price Tractor Pull
