WANTED: D4 5T Oil Capacities or Data/Spec Sheet
TheFourthHorseman
Send a private message to TheFourthHorseman
I'm sure that is has been posted before, but I really need the info. None of my books seem to have this info in them 😞
Does anyone have a spec sheet/data sheet for a D4 5T???
I am mainly trying to find one that lists capacities for oil changes/coolant change.
I am preparing to change all the fluids, which I'm sure will be a long and boring process.
Also, any recommendations as far as oil/gear lube would be handy.
THANKS!!!
Mon, Jun 6, 2011 6:05 AM
dick
Send a private message to dick
From form #102 59-1. D4 4G thru 5T capacities - Air Cleaner qt 1 1/2, Crankcase 17, Fuel Inj. Pump Housing 2/3, Radiator gal. 11, Fuel Tank 25. Starting Engine qt. Air Cleaner 1/2, Crankcase 1, Clutch Housing 1/2, Fuel Tank 4. Final Drive qt. 7, Transmission 20.
Mon, Jun 6, 2011 8:39 PM
| Kingaroy, Queensland
