Volume compressors
Volume compressors
D2Fred
Send a private message to D2Fred
[attachment=65881]09E89E5F-B36F-4350-A440-D5DE83F6A027.jpeg[/attachment]I was wondering about a volume compressor for my D2. Is the transfer pumps that are used for filling gear lube into rear axles the same thing? Mine is an old ARO With pump handle. The handle will push one direction and then spring back. The cat ones I have seen are only slightly different ( that I can tell). I can take a picture of mine but I think I described pretty well.
Sun, Dec 19, 2021 1:04 AM
Ryan.E
Send a private message to Ryan.E
Hey folks
I was searching the forum to try and find the answer to the same question D2Fred has.
00 grease is runny enough that I think the gear oil pump would pump it. Does anyone have any input?
Sun, May 22, 2022 9:53 PM
Mschwartz
Reply to Ryan.E:
Hey folks
Might work when it is hot out but the track grease is likely to thick when it is colder. Seems like it would be easier to find a correct volume pump can. The oval Alemite cans or the round ones used for the international crawler seem to work equally well. The liquid pumps like described above work well to flush the oil in the sealed rollers. Might be because there were so many crawlers around here but most any old farm stead has some setting around. Mike
Sun, May 22, 2022 10:12 PM
