volume compressor operation
catdude
Send a private message to catdude
I have a volume compressor that has a squeeze lever on the pump handle.Is the lever used as a valve? Fluid pumps out regardless of whether or not the lever is squeezed. Is this working properly or does the unit need repair?
Sun, May 9, 2010 9:18 AM
Thank you received: 39
Purpose of the valve is to release the pressure when done filling a zerk before moving on to the next one.
Sun, May 9, 2010 9:23 AM
Sasquatch
Thank you received: 5
catdude, the lever on my Alemite pump does the same thing you're describing if I just pump grease out of the hose without it attached to anything. The pressure relief lever seems to work best when I'm hooked up to a fitting and there's a little presure on the system, then the valve vents the excess grease out of a little hole just inside the top of the pump, returning it for recirculation.
Sun, May 9, 2010 9:50 AM
catdude
Reply to Sasquatch:
Good to know. Thanks for your help guys!
Mon, May 10, 2010 9:58 AM
