Video of Holt 45?
Video of Holt 45?
David Parfitt
Send a private message to David Parfitt
I came across this video on YouTube which apparently shows a Holt 45. It has a front tiller wheel though, so if it is a 45 then it must be a pre-WWI one. Any thoughts on this? Does anyone recognise the tractor?
http://www.youtube.com/user/fense18#p/a/u/2/ynNx1myyJAk
David
Fri, Dec 2, 2011 6:44 PM
BillWalter
The video of the Holt 45 was pretty good.
Two other videos attached were of starting a D9 and a 60 Diesel conversion.
The D9 starting engine was started at full throttle and it looked like it was a very cold day. I wonder if he starts his pickup at full throttle on a cold morning? As soon as the diesel starts to turn over it;s smoking. Why do people start a cold Diesel with the throttle in the on position? That pumps raw fuel into cold combustion cylinders and all you're doing is washing down the cylinder walls reducing compression.
Read the operators manual on starting a Diesel equipped with a starting engine and no where does it say to "open the throttle first". If that so called operator would have allowed the starting engine to warm up a bit, it would have circulated some warm water to the Diesel engine and warmed up the intake manifold, plus reduced a lot of wear on the starting engine. Then, if he would have run the Diesel engine with compression "on", it would have built up heat in the cylinders and started a lot better.
It is so unprofessional to start a Diesel engine the way both the D9 and Diesel 60 operator started those engines. The majority start a Starting engine equipped Diesel Engine the "wrong way".
Come on guys, lets get it right and save your engines and reduce the amount of "Holding the bendix
engaged". Start them the right way and you'll see very little smoke(un burned fuel) and it makes you
"LOOK A LOT MORE PROFESSIONAL" Bill Walter
Sun, Dec 4, 2011 12:08 AM
gwhdiesel75
Reply to BillWalter:
Bill, very well said. I see guys at shows that don't run the diesel on compression to warm it up. My Diesel Thirty-Five will start at 10 below if the main is run on compression for 20 or 30 minutes. Thanks for posting this reminder. GWH
Sun, Dec 4, 2011 12:35 AM
gwhdiesel75
Reply to gwhdiesel75:
At 14 above 0 F. in Denver this morning, would have to run on compression for a while before starting. Much, much better than watching someone try to start cold with ether. I hate to see ether applied as the first measure in starting a cold engine. Yet, a lot of guys do it. GWH
Sun, Dec 4, 2011 10:10 PM
8D-132
Send a private message to 8D-132
Hot or Cold Days it does not help when you kill the Diesel engine with just the compression lever! I have seen a few of those going on at shows! :jaw:
Mon, Dec 5, 2011 1:05 AM
| Kingaroy, Queensland
