Valves for a big twenty
Clipperno3
Send a private message to Clipperno3
Does anyone know the part numbers for the intake and exhaust valves or a source for new valves for a big twenty. Also it seems I read somewhere here that someone is reproducing the exhaust manifold for the twenty. Thanks in advance.
Fri, Dec 5, 2014 6:20 AM
Mike Meyer
Thank you received: 6
Hi, Exhaust valve is L-721 which becomes OL0721 with Cats new parts numbers, inlet valve is L-720 which becomes OL0720, sorry can't help on a source but someone will chime in.
Good luck
Mike
Fri, Dec 5, 2014 6:36 AM
truckun95
Send a private message to truckun95
Reply to Mike Meyer:
Good luck
Mike
As Mike mentioned above with the updated part numbers reflect the current part number Cat has used. I was able to get them directly from my local Cat Dealer a few years back using those numbers. During that time there were some sitting in the Morton, IL warehouse, not sure if you have tried the dealer and I have not checked recently but worth a call. I recently found out through my parts guys that there is another part of Cat that is or has been collecting and storing some parts that have been discontinued, my part guy has called to check with them a time or two. Seems the parts are not in the parts system and not available but might still be availiable by the part number and a phone call. Might check with the parts guys on it.
Ryan
Fri, Dec 5, 2014 10:23 AM
Clipperno3
Reply to truckun95:
Ryan
Thanks guys, I will do some informed searching now.
Sat, Dec 6, 2014 5:26 AM
truckun95
Reply to Clipperno3:
Here is a link to the parts store and still available through CAT. Search part number OL0720 and OL0721 for valves, almost certain the valve springs are still available also if any need replaced also. Good tool to search part numbers also
https://parts.cat.com/
Sat, Dec 6, 2014 6:16 AM
