Valve guide part number question
Showing 1 to 10 of 10 results
Catboy1
Send a private message to Catboy1
I have recently come across some valve guides, part number 4F6949 A. My parts books say they will fit on the D315 and early model D318's. My D6 9U is in the 27### range. Will they work on that engine? Thank you,
Robyn
Tue, Aug 10, 2021 7:39 AM
Valve guides (bushings) part number changes to a 4H0621 at s/n 9U17,207 up.
Tue, Aug 10, 2021 7:54 AM
Catboy1
Thank you. Do you happen to know the difference? It looks like all head assemblies are the same part number, and the valves as well.
Tue, Aug 10, 2021 11:07 AM
josh
Thank you received: 14
I see several heads that can use either the 4F6949 or 4H0621, used on 9U1- 29764 and 7U1-44307 and others.
Tue, Aug 10, 2021 11:12 AM
Reply to josh:
They are different, maybe not by a lot...
4F6949 length = 4.188" vs 4.250" for the 4H0621
4F6949 OD = 1.062" vs 1.562" for the 4H0621
4F6949 ID = 0.4375" vs 0.4400 for the 4H0621
Other shape dimensions are also different.
All my literature shows distinct different valve guides across the s/n's.
Tue, Aug 10, 2021 12:10 PM
josh
The 4F6949 and 4H0621 guides are quite a bit different, but they are both used in the same head assemblies, and with the same valves and springs in both. Looks like the 4H0621 is a one piece guide, but the 4F6949 also requires an additional part, spacer 5F3110 if you were going to replace the 4H0621 with 4f6949.
Tue, Aug 10, 2021 1:05 PM
Catboy1
Reply to josh:
Thank you very much. Old Magnet, what books do you have that give you the measurements of the parts?
Wed, Aug 11, 2021 12:42 AM
Thank you received: 62
Reply to josh:
The heads on a 318 are as tuff as any you will find, but it still may have been changed in 60 years. So the head may be the earlier type, so check before looking for other guides.
Wed, Aug 11, 2021 12:43 AM
Catboy1
Reply to Ray54:
What do you mean by the earlier type? My parts book is from 9U13263 up, all of the heads are the same number in there. Was there a different style before those serial numbers?
Wed, Aug 11, 2021 4:43 AM
Reply to Catboy1:
The OD makes quite a difference in the press fit.
The ID is significant when selecting the valve seat grinding pilot.
Early heads, part number 5F1305, casting #3F9903 were used to s/n 9U11704
Late heads, part number 1H7659, casting #7F7878 were used 9U11705 up and have the larger diameter pre-com chambers to accept glow plugs.
Wed, Aug 11, 2021 4:58 AM
Thank you received: 93
here is what I could find on updates to valve springs and guides for the 4 1/2" bore engines.
Wed, Aug 11, 2021 8:08 AM
