Valve adjustment on a THIRTY
YeLLoIrOn
Send a private message to YeLLoIrOn
What's the intake and exhaust setting on ser# PS 90. Fixing to put the head and radiator back on and wanted to know the correct setting. I figure its probably not far off of .015" I and .020" EX. 😄
She started getting hot worse and worse every time we started it after rescuing it from the pasture. We found that it quit circulating water. Wound up having to clean the lower water pipe out, bottom tank, radiator tubes, top tank, and pull the cylinders and rod them out. The cylinders were so stopped up with rust that sitting on the bench 2 of them you could fill with water and it would'nt flow out the lower port!😮
http://i26.photobucket.com/albums/c148/blky2k2z/Picture089.jpg
Sun, Dec 27, 2009 12:01 AM
Thank you received: 95
Hi YI,
My books show 0.015" lash for both In and Ex with engine hot, I would Adj them to 0.017" cold and recheck when hot. Also would advise recheck head tensions after first run and again after say 100 hrs.
Hope this helps and that you all had a great xmas.
Sun, Dec 27, 2009 6:28 AM
YeLLoIrOn
Reply to edb:
Hi YI,
edb, thanks for the info maybe tommorrow i can get it out and play in snow drifts now after i put it back together 🙄 Christmas was good other than have to run the front end loader on our johndeere for a 1/2 mile just to get to a main road thru the 3-4 foot drifts.
Sun, Dec 27, 2009 7:42 AM
