Value Group 7F4307 44 control unit
Showing 1 to 10 of 15 results
cfbromm
Send a private message to cfbromm
Could use some advice on stem and base unit. Disassembly the unit and found rust and some deterioration on the stem and not sure of the base.Can this be repair or replaced. Any advice on this matter. Thanks for any advice.
Tue, Oct 10, 2023 8:43 PM
Thank you received: 288
I will be following this thread. Many of us have 44s as well as 41s, I would guess that has affected the operation of your pump?
It would be interesting to know if a hydraulic shop can "Parkerize" it, and lap it smooth, or have a machine shop (crank or camshaft experts?) rebuild it to specs?
You would not be the only one with this situation, being these units are so old.
One wonders if a new one is floating about in the inventory of a dealer somewhere.
Keep us posted on any progress please. JM
Tue, Oct 10, 2023 10:07 PM
josh
Thank you received: 14
That looks pretty bad, I would bet the valve body is bad as well. It is my understanding that the spool and body are a fitted pair and as such, it may be difficult to repair. Your best bet might be to find a good used valve assembly, they were used on lots of tractors and most dismantlers seem to have something around, one of those things, that if you work on them very often, you pick up units or parts when you can.
Tue, Oct 10, 2023 10:25 PM
cfbromm
Thanks for the advice.
Maybe there is one available.
Tue, Oct 10, 2023 10:34 PM
josh
Reply to cfbromm:
https://www.acmoc.org/bb/for-sale-wanted-d6/30861-no-44-hydraulic-control-unit
Wed, Oct 11, 2023 10:13 AM
Thank you received: 54
Reply to josh:
maybe devcon epoxy or silicon bronze to build up the worn areas line bore the the body to a size and then machine the spool to that size.
thats how they were made the body was rough made undersize and the shaft was oversize and then machined to fit each other
silicon bronze would be my preference.
any decent machine shop should be able to do this.
Wed, Oct 11, 2023 2:56 PM
cfbromm
Reply to josh:
Thank you for the offer of the hydraulic 44 unit. I'll keep that in mind. It is the distance from me.
Wed, Oct 11, 2023 8:02 PM
josh
Reply to cfbromm:
That is not my hydraulic unit, just posted it to show they come up. Where are you located? I may have a valve assembly but it will be a few days before I have time to look.
Wed, Oct 11, 2023 9:53 PM
cfbromm
Reply to josh:
Josh
Thanks, for the response.
Yes, if would find value, let me know.
I'm in northern Minnesota.
Thanks again
Corky
Thu, Oct 12, 2023 7:58 AM
josh
Reply to cfbromm:
Josh
Thanks again
Corky
What is the condition of the cartridge (pump) and input shaft, just wondering since the spool is so pitted.
Thu, Oct 12, 2023 8:09 AM
Reply to josh:
the cartridges were available from eaton fluid power. they were made by sperry-vickers which became part of eaton.
Thu, Oct 12, 2023 1:38 PM
