V8 powerd D7
V8 powerd D7
Showing 1 to 10 of 44 results
roly66v
Send a private message to roly66v
Russel Seywell,s latest creation,a cat powerd V8 grafted into an
old D7,it looks and sounds the business,can be seen working at
his next open weekend and i wonder what box he,ll hang on
the back,great job👍i wonder what will be next.?
[img]http://i481.photobucket.com/albums/rr179/rolyd8k/IMG_555732.jpg[/img]
[img]http://i481.photobucket.com/albums/rr179/rolyd8k/IMG_555932.jpg[/img]
[img]http://i481.photobucket.com/albums/rr179/rolyd8k/IMG_556032.jpg[/img]
[img]http://i481.photobucket.com/albums/rr179/rolyd8k/IMG_556132.jpg[/img]
Sun, Jan 23, 2011 5:17 PM
bigkit
Send a private message to bigkit
Hey Roly, he must have too much time on his hands just to think up a job like that!😆
Sun, Jan 23, 2011 5:22 PM
chriscokid
Reply to bigkit:
post some vids of it running i bet it will sounds as mean as it looks.
what will be the rpms with the new motor?
orgional spec:
Cylinders bore and stroke 4@5-3/4"x8"
RPM 850
Sun, Jan 23, 2011 8:27 PM
zootownjeepguy
Reply to chriscokid:
orgional spec:
RPM 850
I once, years ago, bought some D2 parts from a guy that had a lot of "junk" laying around. He had a D6 that he had removed the diesel (because he "didn't like diesel engines") and repowered it with a 327 Chevy. It turned out to be very underpowered, barely enough power to get out of it's own way.😆
However, this repower looks COOL👍. What motor is that? Was it a Genset?
Rich Salvaggio
D2 5U9917
Sun, Jan 23, 2011 9:44 PM
cojhl2
Reply to zootownjeepguy:
[quote="zootownjeepguy"]I once, years ago, bought some D2 parts from a guy that had a lot of "junk" laying around. He had a D6 that he had removed the diesel (because he "didn't like diesel engines"😉 and repowered it with a 327 Chevy. It turned out to be very underpowered, barely enough power to get out of it's own way.😆
However, this repower looks COOL👍. What motor is that? Was it a Genset?[/quote]
You know that's kinda funny how that works. Years ago a guy here re-powered a Gas Sixty with a Cadillac V8 complete with Hydramatic.
I watched that at work in the river and it was almost worthless. The engine overheated and the tractor could only do a fraction of the work the original 4cyl did. HP does not always = HP I guess.
Sun, Jan 23, 2011 10:54 PM
Wow, that's some conversion....looks well done.
That's a D17000, used in Locomotives, Electric Sets, Industrial and Marine applications.
RPM range from 750 - 1000
Hp: 145 to 200
1662 cubic inch displacement ( about double the old D8800 displacement of the D7)
Thanks for the pics.
Sun, Jan 23, 2011 11:01 PM
zootownjeepguy
Reply to cojhl2:
It's the torque that does the job. V8 car engines have lot's of horsepower at higher rpm's but no torque at slower speeds.
Rich Salvaggio
D2 5U9917
Sun, Jan 23, 2011 11:02 PM
catfan
Send a private message to catfan
Are the holes in the starting engine fly wheel used for statring it with a bar like a 60? Never have seen that before. I think that would make a great scraper puller! Nice job.
Mon, Jan 24, 2011 12:09 AM
snowshoveler
Send a private message to snowshoveler
Reply to catfan:
I could be wrong and many times are...but didn't Deas take a V8 powered crawler for a spin in some video here.
I think it had the very same sort of engine in it,however I think it was in a D8.
Movie was at one of the big gatherings a year or 2 ago.
Chris
193? d4400 cat powerunit
1950 john deere M
1959 international t5 crawler
1977 powerking 1216 tractor
Mon, Jan 24, 2011 12:22 AM
d4c24a
Reply to snowshoveler:
Chris
i look forward to seeing it in action this years Roly ,i hope you can make it too as Russells is a good day out 👍
D8 V8
http://www.youtube.com/watch?v=p5l4edbmUg0
Mon, Jan 24, 2011 12:30 AM
Reply to d4c24a:
D8 V8
Yup, bar start was the base offering, electric start pony was an option as seen on this unit, also could mount an air motor starter.
Interesting note on the big pancake pony....they started out with roller bearing mains but switched to the sleeve type after having rusting problems on units that sat idle for long periods of time.
Mon, Jan 24, 2011 12:48 AM
