Use gasket sealant or not?
Todd
Send a private message to Todd
I'm getting ready to reassemble parts on my D2-5U pony motor. I'll be putting the carb and magneto back on, as well as the oil filler assembly and the air intake parts for both the pony and main engine.
I have new gaskets - do I need to use gasket sealant? If so, what do you recommend?
Thanks, Todd
Tue, Sep 1, 2009 10:36 PM
Arthropod
Send a private message to Arthropod
I don't use gasket sealant on carbs. Other connections I often use the non hardening permatex.
Tue, Sep 1, 2009 11:03 PM
Thank you received: 46
Reply to Arthropod:
On exhaust flange gaskets and other take it apart joints I use a coating of high temp anti seize.
Tue, Sep 1, 2009 11:08 PM
