UNS thread size - where to find?
Arthropod
Send a private message to Arthropod
I started a new thread regarding the D2N winch drum nuts.
In doing some searching, I find information regarding the size I am trying to find, 1-3/4" x 10 TPI.
Apparently this is a UNS designated thread size - Unified and American threads of selected special diameters and pitches (also called Unified Special).
Typical threads are UNC and UNF (Unified course and Unified fine).
I am not having much luck finding any place selling UNS style nuts. At least I am starting to understand what I am searching for and have something else to plug into Google.
I did find a tap - http://www.hermanscentral.com/product/qual-tech-13410-high-speed-steel-tap-13609.cfm
Thu, Jul 23, 2009 10:28 PM
SpragueM
For the price of that tap a machinist could almost whip you up a nut or two. Do you have any more info? I can look in my Machinerys Hand book to find distance across flats. Do you know how thick of a nut you need?
I am working at the shop this weekend. Could do something for you. Let me know.
Matt
Fri, Jul 24, 2009 4:38 AM
firekat
Send a private message to firekat
Reply to SpragueM:
Matt
Hello
Just a thought hear but if you get some hex stock, drill some holes and tap your own nut as thick as you need. Just a thought
firekat😊
Fri, Jul 24, 2009 6:30 AM
STEPHEN
Reply to firekat:
Hello
firekat😊
I may have the drum nuts as someone stole a buch of "scrap metal" i.e. old cat parts and a dissasembled winch. Or I could make the nuts for you no problem,
Fri, Jul 24, 2009 12:56 PM
Arthropod
Reply to STEPHEN:
STEPHEN, I sent you a message.
To all, thanks for the replies. I do have a lathe and will make something if I can't find some nuts. I was just hoping for originals if possible.
A friend mentioned that I take some round stock and make two threaded collars and drill holes so I could use a spanner wrench. That would work, but isn't original. But I'll go that route next.
Mon, Jul 27, 2009 10:26 PM
