Unknow Tractor - Help Identify
n7gxz
Send a private message to n7gxz
A friend on another board, non tractor, posted this picture of his dad on a tractor but we have not been able to determine what it is. Any recognize it?
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Wed, Aug 12, 2009 10:05 PM
gauntjoh
Librarian
Thank you received: 5
I believe that is an International TracTractor 40, also known as a T-40 Diesel, made between 1932 and 1939. This was the first International crawler to be fitted with a diesel engine, and started on petrol then switched over to diesel.
Wed, Aug 12, 2009 10:45 PM
side-seat
Reply to gauntjoh:
Looks like just a T-40 gas.
Wed, Aug 12, 2009 11:45 PM
n7gxz
Reply to side-seat:
I think it is a TD-35.
[img]http://images.wisconsinhistory.org/700003050698/0305007554-l.jpg[/img]
Kevin
Thu, Aug 13, 2009 5:09 AM
2HIGHTEN
Send a private message to 2HIGHTEN
Reply to n7gxz:
Kevin
It is a diesel of either 35 or 40 but I do not know how to tell which from that photo, but the carb and mag make a diesel for sure and the air cleaner has the large in hood mounting . The gas models used a six cylinder engine and a smaller air cleaner ,easy to ID. The diesel was a four banger.
Thu, Aug 13, 2009 8:20 AM
gauntjoh
Librarian
Reply to 2HIGHTEN:
I believe 2HIGHTEN is correct. On closer inspection, the track frames, where the front idler adjusting assembly is located makes it a TD35 not a TD40, well spotted that man !!
Thu, Aug 13, 2009 8:58 AM
u-joint
Send a private message to u-joint
Reply to gauntjoh:
yes that is a TD-35. the 40's had five lower rollers and 95% that i have seen
have a covered or solid drive sprocket
Thu, Aug 13, 2009 10:17 AM
bob
Send a private message to bob
Reply to u-joint:
Yes John, the TD40 had the idlers mounted on links the same as a Cat Hystat loader does today.
Later Bob
Thu, Aug 13, 2009 6:37 PM
Gordon.
Send a private message to Gordon.
Dark Green would be a colour that i've seen them painted.
Gordon.
Fri, Aug 14, 2009 4:06 AM
