Undercarriage Files II
Showing 1 to 10 of 11 results
Thank you received: 61
Please do not reply to this post yet as I have set it up for Joe B. to post the file pictures.
[img]http://www.acmoc.org/Ref_Pics/OM_UC/Carrier Roller.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/DCP_0917.JPG[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Elongated Sprocket Teeth.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Excellent Sprocket.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Good Undercarriage .jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Good Undercarriage 3.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Grease Type Rollers.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Lifetime Lubed Rollers.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Misalignment.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Rollers Hitting Pin Bosses.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Shot Undercarriage.JPG[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Snow Sprocket.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Weld built up idler.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Weld on grousers .jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Worn Bushings.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Worn carrier rollers.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Worn Out.jpg[/img] [img]http://www.acmoc.org/Ref_Pics/OM_UC/Worn Sprocket.jpg[/img]
Mon, Dec 18, 2006 8:56 AM
With a little help from JB. Thanks
Wed, Dec 20, 2006 11:19 AM
gwhdiesel75
OM, an impressive collection of photos on undercarriages. Thanks. Makes it more understandable. GWH
Wed, Dec 20, 2006 8:13 PM
Catmandu
Send a private message to Catmandu
Reply to gwhdiesel75:
OM,
Thank you, for the newbies that haven't been around tracks this is a good primer.
I could see a "how to" folder that helps all. How to: remove a pony, How to:install a direct start, How to: audit an undercarriage etc.
Well done
CMD
Wed, Dec 20, 2006 9:46 PM
Reply to Catmandu:
OM,
Well done
CMD
Hi Catmandu,
Yes, that was my intent, to get some visuals out there for those that are unfamiliar with undercarriage. The pictures are not exactly laid out the way I would like but I'm still getting used to the editing function. I have plenty more pictures, specifications and a complete Cat Inspection and appraisal guide that I may eventually post, but not until some form of archive is established. The direct start conversion material already exists and is accessed through imageshack. Somehow the link got lost in the shuffle of re-registering but I will put it back in my profile information. Thanks for the comments.
Wed, Dec 20, 2006 11:36 PM
bernie
Hi Catmandu,
OM-Thank you. Your work, time and resources are appreciated.
bernie
Thu, Dec 21, 2006 12:48 AM
Manx Kat
Send a private message to Manx Kat
Hi Catmandu,
Beautiful job its good to see this very valuable info. on here. I am sure many will put it to good use. As I sure will try to save it some how.
For me this is what is what this site needs. As catmandu suggests the other files woud be very valuable also if they to can be put on here. I hope to see them soon.
D.K. inS.K.
Thu, Dec 21, 2006 12:51 AM
Lee
Send a private message to Lee
Reply to Manx Kat:
D.K. inS.K.
Is there a specified service limit to a rails thickness?Do the older machines have heavier or lighter rails?How would newer rails interchange with a Cat 30?
The photos are great.It is easy to compare them to each other.
Thu, Dec 21, 2006 10:27 AM
Al Letts
Send a private message to Al Letts
Reply to Lee:
๐Ÿ˜Š Hi All,
Here is the link for the subject pages. Thanks again to Old Magnet and Swishy for pulling the page and information together.
http://img400.imageshack.us/gal.php?g=header4oq.jpg
Alan
AL
D2-5U-10614
Thu, Dec 21, 2006 11:22 AM
Yes there's a spec on all the undercarriage components except maybe the sprockets, never seen any measurements there.
Here's some track information
http://www.crawlerheaven.com/wearlimits.htm
and here
http://www.crawlerheaven.com/tracklinks.htm
I think the newer tractors rails are generally taller than the comparable old tractor. Compare D2 and D3, and D6 and D5
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Thu, Dec 21, 2006 11:33 AM
Delta Dirt
Send a private message to Delta Dirt
and here
Good illustrations Magnet.
Also thanks to Al and CC for bringing in the other sites for some detailed info----and thanks to Joe for helping with Magnet's pictures.
This is a start in the right direction anyway.
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
Thu, Dec 21, 2006 12:57 PM
