Undercarriage Data
Undercarriage Data
Showing 1 to 10 of 22 results
Recent discussion got me digging into undercarriage component hardness and heat treating.
Track Shoes
Track shoes are medium carbon steel, furnace or induction hardened, die quenched and tempered.
Typical hardness range is Rockwell "C" scale 32 to 40
Grousers are a little harder at Rc 41 to 49.
If they were Rc60 they would be far to brittle for the application and not practical to drill.
Rc60 is what roller and ball bearing races run.
Multi flute core drill (short nose taper) or multi flute (bridge reamers) long taper to finish size are preferred for drilling over say a common two flute drill.
Track Links
Track links run a rail hardness of Rc53 with a core hardness of Rc36.
Bushings
Bushings run a surface hardness of Rc60 and a core hardness of Rc38.
Pins
Pins run a surface hardness of Rc60 and a core hardness of Rc15 to Rc30
Sprockets
Sprocket rims run Rc45 to Rc48
Track bolts and nuts
Track bolts & matching nuts have a surface hardness of Rc50
Bolt tensile strength is 160,000 psi through 1" diameter. Above 1" diameter is 180,000 psi.
None of the undercarriage parts are through hardened and all have variable depths of hardness.
Wed, Dec 10, 2014 1:08 AM
OM--any info on the yield strength of the track bolts?
Wed, Dec 10, 2014 4:52 AM
OzDozer
Reply to dpendzic:
Dan, all the Cat hardware specifications are listed in the chart below, along with dimensions and P/No's.
https://parts.cat.com/wcs-static/pdfs/09_OSS_Hardware_low_res.pdf
OM, thanks for the hardness update, I was relying on memory for the previous shoe hardness quote, I should have referred to the books for preciseness.
I might add, I have seen specs for some aftermarket shoes where they were rated at 58RC hardness.
The hardness will vary according to age of the item, there have been substantial and major improvements in steel qualities, steel hardness, and hardening and tempering techniques, over the last 50 yrs.
I have been amazed at the lifespan of some of the newer, latest quality Cat undercarriage, I have seen D9T undercarriage that has done 7000 hrs and the wear was minimal.
In the bad old days we were lucky to see 5000 hrs before the undercarriage was totally scrap.
Wed, Dec 10, 2014 5:53 AM
Reply to OzDozer:
No specific data other than track bolts exceed Grade 8 standards of minimum 150,000 psi tensile and 130,000 psi minimum yield.
Wed, Dec 10, 2014 5:59 AM
shovel man
Hi OzDozer
Was that system one undercarriage on the D9T ?
shovel man.
Wed, Dec 10, 2014 10:21 AM
OzDozer
Reply to shovel man:
Hi OzDozer
shovel man.
Shovel man - No, it wasn't, it was just the older, standard-design Cat SALT undercarriage.
It was one of my middle nephews D9T's, he owns a big fleet of Cats (about 60), and he always has the latest Cats in his fleet.
His tractors do a lot of mining work (he dry hires to many mining companies) and they get all kinds of abuse, but they stand up to it well.
Of course, if there's anything needing repair when they come back off hire, he just gets it fixed and sends them the bill - and they pay up! Way to go! 😊
I'm not sure if he actually has any System One undercarriage in his fleet, I can't keep up with his purchases!
Here's some pics of his machines ...
http://www.nashbros.com.au/dozers.html
Regards, Ron.
Wed, Dec 10, 2014 10:41 AM
Reply to OzDozer:
Regards, Ron.
You might get away with 58Rc on narrow shoes on dozers or on traxcavators but that's the wrong metallurgy choice for anything wide.
Wed, Dec 10, 2014 2:33 PM
OM--thats about a 15% increase in tensile over yield strength--i would surmise that they do not stretch very much.
Ron---thats quite a comprehensive chart on the hardware!!
Wed, Dec 10, 2014 9:28 PM
Reply to dpendzic:
That's correct. Probably why torque procedure on 3/4" and up track bolts are tightened to an initial torque plus 1/3 turn rather than just a final torque. (with anti-seize)
Wed, Dec 10, 2014 11:38 PM
Thats interesting---that 1/3 turn is the alternate procedure for A325 HS Bolts for bridge beam connections one other method was to calibrate a toque wrench each morning on a 15/16 bolt in a load cell to get a 30,000# tensile load-=-another procedure was load indicating washers but we didn't allow them as the gap at the washer would allow moisture and rust in the severe salty environment---most of our bridges are in close proximity to the Atlantic
Thu, Dec 11, 2014 3:15 AM
Reply to dpendzic:
I thought those load indicating crush washers had nubs on them that were supposed to remove the gap when properly torqued?
Thu, Dec 11, 2014 4:15 AM
