Under size D2 track rollers
microlink
Send a private message to microlink
Been working on D2 track rollers. Have a few that are undersize. Can I build?
them back up, and what rod/wire would be the best choice? I’m thinking about
using the MIG, I can build a robotic fixture to help get a flatter more even bead
than I can do by hand. Can I make a complete face pass in one run, or would that
be too much heat? Do they need to be cooled very slowly after the weld?
Sat, Dec 18, 2010 4:41 AM
I have welded up many rollers with weld. Have to be very careful with the heat--have used a water bath when anxious to get the welding done quickly---i have used 6013 rod and 7018 rod.
Sat, Dec 18, 2010 11:41 AM
Thank you received: 31
Reply to dpendzic:
here are some scans of the Caterpillar Roller Reclaimation Section of a Conservation publication Cat put out in the early 1950's.
depenzic gives good advice on a cooling method if you need to expedite the job.
Looks like we still have the old dead horse of "load it in any order" but what I choose.
Hope this helps.
Sun, Dec 19, 2010 5:51 AM
microlink
Reply to edb:
Hope this helps.
[quote="edb"]Hi Team,
Hope this helps.
Eddie B.[/quote]
Thanks depenzic and Eddie. You have given me much to think about. I'll measure and consider my options. Anyway thanks, I always wanting an excuse to buy a surface grinder and radial to boot, aint toys grand!👍
Mon, Dec 20, 2010 9:40 AM
