type of oil
type of oil
Showing 1 to 10 of 13 results
bullcrk,6
Send a private message to bullcrk,6
picked up a clean D5SA 98J farm cat recently to retire the 9U to dozer work only, getting ready to change all
compartments with new oil and the book calls for sae 30 engine oil in the trans,bevel gear and flywheel clutch housing and 50w engine oil in finals.I know someone is going to poke fun at me but i am struggling with this,i am old school and like 90wt gear oil in trans and bevel gear and 90 or 140 gear oil in my finals, I don't normally question the cat books but was looking for others opinion on this.
Thu, Jul 17, 2014 9:03 AM
I agree with you..............except if any of those compartments have a pump and filter. Then I would stick to the lighter weight oils. I might instead use a light weight gear lube, but don't know how light is actually available.......maybe 75 wt??
Note......gear lube "weight" and engine oil "weight" are not on the same scale. So a SAE 50 engine oil is more like a 75W-90 gear lube I think.
Any clutch compartment/powershift transmission should have a drive train oil in it. Motor oils probaby don't offer the best performance there and gear lubes are not appropriate either.
Thu, Jul 17, 2014 10:53 AM
flmore
Send a private message to flmore
I had the same issues. My local oil supply co explained it this way. 50wt motor oil is the same viscosity as 90wt gear oil. The difference is that motor oils have detergent in them, unless you purchase a non detergent. If the spec calls for 50wt, use that, not the non detergent.
Thu, Jul 17, 2014 11:22 AM
bullcrk,6
Reply to flmore:
thanks for the reply gents, i was going to go with the book on this it just seemed a little odd to put motor oil in gear compartments 30wt motor oil in a manual trans scares me but it must do the job. thanks again
Thu, Jul 17, 2014 11:41 AM
Reply to bullcrk,6:
I think once again we need OM's viscosity chart--I know i printed it out but can't find it---good candidate for the tech library.
Thu, Jul 17, 2014 8:59 PM
seiscat
Reply to dpendzic:
Hello bullcrk,6. The transmission and bevel gear compartment also includes the steering clutches and relies on a pump and filter to operate. Cat designed the transmission to operate on the 30W motor oil. You must have been taught as I was on older machines where motor oil was for motors and gear oil was for gears. What was true then does not always remain true. I bought a new Camaro Z-28 in 1983 with a 5 speed manual transmission. I was shocked when both the dealer and the owner's manual said ATF went in that manual transmission.
There is a little wiggle room on the finals as they do not have a pump or filter.
When in doubt, rely on the manual for your machine.:cool2:
Happy 'dozing
Craig
Thu, Jul 17, 2014 10:00 PM
lil cat mec
Send a private message to lil cat mec
Reply to seiscat:
Happy 'dozing
Craig
I am finally a CAt Mechanic and all we have on the wall is 15-40 engine oil, 10wt for hydraulics, 30wt for transmissions(and some other compartments) and 50wt for finals and axles, etc. if we need 90wt we have to order it, there is a reason for that, tighter cleatances need thinner oil, this is all SAE Engine oil not Gear oil im not saying their the best but its my .02.
but there is always grey areas, like the getrag 5 speed transmission in my 1993 dodge cummins, i over fill it a quart to lube the bearings better, so therefore there is always grey areas
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
Thu, Jul 17, 2014 10:06 PM
Reply to lil cat mec:
One more time.....
Fri, Jul 18, 2014 12:22 AM
bullcrk,6
One more time.....
well just so happen i was at both my local cat dealer and my oil and fuel supplier today and what i got from both my go to guys was if i want to put gear oil in the finals, same as the older cats go ahead, but the trans,clutch,bevel gear compartment 30wt drivetrain oil is the way to go, not motor oil or gear oil 50wt drivetrain oil is what cat puts in finals as well. truth be known the oil companys prob make a few diff oils and just label the containers different and we don't know the difference and they laugh all the way to the bank.makes me wonder some days you keep 30wt for the old cats, 15/40 for newer ones, 15/40 synthetic for the new isx cummins motors ,synthetic gear oil for the truck drive trains regular gear oil for the rest 3 0r 4 diff wts of oils greases hydro oils you almost need a ware house just for oil storage. and we prob only need a cpl diff oils and they would work in everything.
Fri, Jul 18, 2014 7:13 AM
seiscat
Reply to bullcrk,6:
Thanks for once again posting the chart Old Magnet. In the nineties my Cat dealer told me to start using "drive train oil". I had no failures using Series 3 30W motor oil in the bevel gear compartment as my service manual listed for all my tractors. I could not justify having two 30W oils, and feared the results of an operator accidentally adding drive train oil to a engine. I had no issues until I sold these machines in 2000.
I was told that later model machines had a different composition disk material for steering clutches and power-shift transmissions that required the "drive train oil".
I think using the motor oil as listed in the service manual is okay if the trans/steering clutches are the original design.:target:
Someone please clarify the drive train/motor oil issue. What happens if drive train oil is put in the engine?
Thanks,
Craig
Fri, Jul 18, 2014 8:32 AM
Reply to seiscat:
Thanks,
Craig
what is drive train oil--I have never heard the term before--are you talking about TO4 oil used in powershift and wet clutches?
Fri, Jul 18, 2014 9:36 AM
