two ton Caterpillar
two ton Caterpillar
carole walker
Send a private message to carole walker
Our two Ton has hard steering when you pull the tiller bar to either side it takes a lot of effort. At a show last week an operator advised the two tons he had run were not that hard to steer. I have the service manual but no help there. Any advise would be welcome.
Gene
Mon, Sep 21, 2015 7:21 AM
Mike Meyer
Thank you received: 6
I have a couple of 2 Ton Cats and I find them harder to steer than say the 22 or 15, it takes a good 2 handed pull on that tiller to overcome the clutch spring pressure and I assume that is because they are running in oil unlike the dry clutch packs on the other Cats which are light on the controls in comparison, if you are pulling a implement the 2 Ton will turn much easier and make sure you are running 30W oil in the back end, not 80-90W or 85-140W, but even when the 30W oil is cold they take some turning.
Regards
Mike
Mon, Sep 21, 2015 7:31 AM
carole walker
Reply to Mike Meyer:
Regards
Mike
Thanks Mike I may not have a problem just a hard turning tractor. the old operators must have been strong.
Gene
Mon, Sep 21, 2015 9:11 PM
Skinner
Thank you received: 38
Reply to carole walker:
Gene
Try draining the steering clutch compartment one my two tons wasn't steering right when I drained it the oil was so thick it was like 00grease. After flushing it out clean and putting new oil it steers really nice now. JM
Tue, Sep 22, 2015 5:27 AM
