Two piece piston
Two piece piston
clayton
Thank you received: 13
Hello I have several early pistons that are the two piece design, I know they are basically drilled and pinned 180 degrees apart what’s the fix when the outer portion starts to get loose and shift? I don’t want to buy newer pistons if I can simply drill and pin them in more than just two spots any info is much appreciated.
Sat, Mar 22, 2025 10:05 PM
MSTEC STEAMFEST
