Twenty two water pump
Farmer12
Send a private message to Farmer12
Are these available somewhere or is there some where to have them rebuilt? Mine just leaks, spins good.
Wed, Jun 5, 2019 8:08 AM
At the junction of the shaft and the packing nut?
On my Fords, you just tighten the packing nut a little, the 22 should be the same. If the nut won't tighten chances are the packing is worn out. I've bought graphite impregnated valve packing at the Hardware store to remedy these before. You can get a "Marine" grade of grease you can use to lubricate the water pump bearings.
Wed, Jun 5, 2019 6:29 PM
Farmer12
Reply to drujinin:
I did see the nut but I haven’t taken it apart yet. I will try that. I believe that’s where it’s leaking but not positive.
Wed, Jun 5, 2019 8:37 PM
