Twenty Two on old farmstead
beaver-flat
Send a private message to beaver-flat
Found this old cat sitting on an abandoned farmstead. Sad that the exhaust was left uncovered!
Haven't decided if I'm going to acquire it or not. Belongs to a friend (his father's estate)
Fri, Feb 21, 2020 10:42 PM
GrantJ
Thank you received: 13
Its an F model. It probably is not economical to rebuild it but the blade setup is not common on 22s and from the lack of hydraulic lines coming from the back it must be a front pump or the even rarer pump that goes in the generator spot. Cant tell with the weeds in the way, but look for a PTO on the back. Horrible project but a good parts machine. Just my opinion. Grant.
Sat, Feb 22, 2020 8:25 AM
beaver-flat
Reply to GrantJ:
pump is belt driven on left side of engine
Sun, Mar 8, 2020 1:52 AM
GrantJ
Reply to beaver-flat:
I have a 22 with a belt drivin pump on the left side of the engine. I have not used it yet but think it is OK for the hydraulics that came with the project. I will know in a few months. Grant.
Sun, Mar 8, 2020 11:31 AM
