Twenty two brake relining
cowdownman
Send a private message to cowdownman
Can one replace the brake linings on a Twenty two without stripping the final drives?
Fri, Nov 6, 2020 1:57 AM
3J1Bill
I did replace the left brake band on a CAT 22 thru the brake adjustment hole. I only did it once to see if it could be done. I have since replaced all others by removing all the parts including the final drive. Bill
Fri, Nov 6, 2020 10:12 PM
hfdzl
Reply to 3J1Bill:
That's one thing Cat could have done better.on these smaller tractors.
Fri, Nov 6, 2020 11:44 PM
3J1Bill
This is how I did it. The problem I had was removing the brake lever pin. I had to burn the brake lever pin out. I saved a lot of time and work. Done in one day with no help. This was on a tractor I needed to repair fast. When these instructions were written they didn't realize that pin has a semi press blind fit. Bill [attachment=60988]P1040479.JPG[/attachment]
Sun, Nov 8, 2020 10:41 PM
hfdzl
Reply to 3J1Bill:
Bill, thanks for the scan of the 15 service manual. Nice to see these earlier books for reference!
Mon, Nov 9, 2020 5:26 AM
| Hartley - South Australia
