Twenty eight project
Showing 1 to 10 of 19 results
deereskinner
Send a private message to deereskinner
Have this 28 that I’m determined to bring back but it’s going to be a lot of time, engine is loose, main clutch not stuck but not right, steering clutches stuck. Can use exhaust manifold and have located and retrieved a good intake and drop tube, will need to locate or just build something to replace the heat box.  Pins and bushings are shot, sprockets and rollers will be usable. Good tin work all there but engine side panels.  Anybody know if rails or chains are interchangeable with another model?  Is there any truth to they would interchange with a gas thirty or another model?
Mon, Jan 1, 2024 12:23 AM
deereskinner
Even though this poor little crawler is a basket case, I feel at the production number of 1171 that it should be saved. Thats why I have decided to see this twenty eight survive rather than parts tractor. Luckily its a smaller tractor too making it easier to handle as far as tearing components down and handling them. Any advice or criticism would be appreciated. Id better get started pulling finals and get those clutch discs and brakes freed up.
Mon, Jan 1, 2024 12:46 AM
Thank you received: 288
Reply to deereskinner:
It looks straight enough to warrant a makeover of sorts. Not about to knock anyone's iron.
Darn it man, I thought for sure you were going to tell us you scored it 2 miles from home and walked it back in 3rd gear for minor work! Oh well, for the love of tractors.
What's the story line behind this one?
Thanks, JM.
Mon, Jan 1, 2024 1:02 AM
steeltracs
Thank you received: 10
Thanks, JM.
Looks like a very worthy project,keep up the good work. I believe that tracks off a D4 narrow gauge tractor will fit .just less links. See next post!
Mon, Jan 1, 2024 3:00 AM
brian18a
Thank you received: 69
Reply to steeltracs:
Track from Cat 20, 25, 30, 35 and D35 will fit. 30, 35 D35 have more links. D4 rail has a different spacing between rails, so really only fit if rollers are well forn, otherwise rails wear the flanges to fit.
Mon, Jan 1, 2024 3:37 AM
deereskinner
Reply to brian18a:
I wasn't actually looking for any stray cats when I found this one. I was on a trip looking for John Deere 8200 end wheel drills about 40 miles from home when my wandering eye spotted yellow cat hoods in a old barn that was in the yard of this old broken homestead. I got permission to look at them and found a 5t d4 which they wanted to keep and this 28 that I started asking them if it could be bought. Needless to say, I had to make a extra trip for grain drills, plows, and a cat 28. It was a winch recovery but went smoothly. I have access to some near perfect rails that will have to be shortened but at least I don't have to search for any. I counted 29 links on the Cat 28.
Mon, Jan 1, 2024 10:05 PM
Not looking? I have heard that excuse before. Hahahah. I hate it when that happens. Good deal on the 28 and the rest of the goodies you acquired before year end. JM
Tue, Jan 2, 2024 12:03 AM
Mschwartz
Looks like a fun project, good luck on your parts search. Mike
Tue, Jan 2, 2024 12:49 AM
Skinner
Thank you received: 38
Reply to Mschwartz:
I have 2 wide gauge 28s one has pretty good track bushings. Both are for sale. Cleaning the yard of some projects. [attachment=74770]IMG_4715.jpeg[/attachment][attachment=74771]IMG_4716.jpeg[/attachment][attachment=74772]IMG_4719.jpeg[/attachment]
Tue, Jan 2, 2024 3:53 AM
caterpillar13
Reply to Skinner:
the manifold looks ok if it does not have holes in it, i would clean it and use it
Tue, Jan 2, 2024 7:35 PM
deereskinner
Reply to Skinner:
Skinner, I think I bought the manifolds off your twenty eight, so I have your good intake and drop tube, I can use my exhaust, I just need to fabricate a heat box or fill the gap somehow and I should be fixed up, can't think of anything else on your parts cats that I need at the moment, but glad to have the resource, thanks
Tue, Jan 2, 2024 9:21 PM
