Twenty Eight manifold?
shovel man
I’ve got this what I believe to be a Twenty Eight manifold, but the part number on the manifold 1A4936 doesn’t match with the part number in the book 1A4957, is this a Twenty Eight manifold? [attachment=72821]99838A9E-0B1C-4A3D-9338-583CD895C6A0.jpeg[/attachment] [attachment=72822]361D77CA-4D97-4D13-8D91-5557CE8F717C.jpeg[/attachment]
Sat, Jul 1, 2023 1:02 PM
greengiant
Send a private message to greengiant
mine says 1A4936
Mon, Jul 3, 2023 8:55 AM
Reply to greengiant:
mine says 1A4936
That's pretty common for the casting number to be off by a few numbers from the part number.
Story has it that the number of machine operations required to the raw casting helps define the final part number.
Mon, Jul 3, 2023 10:48 AM
josh
Thank you received: 14
1A4936 is a manifold for the Twenty Eight, it is part of the manifold assembly 1A4957 which is shown in the Twenty Eight parts catalog.
Mon, Jul 3, 2023 10:57 AM
naylorbros
Thank you received: 34
Reply to josh:
It will also fit the late Twenty Five tractors.
Mon, Jul 3, 2023 11:38 AM
