Turning pins and bushings
Showing 1 to 10 of 15 results
Jw74
Send a private message to Jw74
Does any one have some good photos of a track all taken apart? I am new at this game and just cant quite visualize the process of turning the bushings and pins. A photo of a track press in the process or removing them would be awesome!
Thanks God Bless
Wed, Dec 10, 2014 10:38 AM
STEPHEN
Check on U tube!, I remember watching some press work there.
Wed, Dec 10, 2014 10:51 AM
OzDozer
Jw74 - Here you go - real, moving video! - better pics than I can find, in any of my files! 😄
https://www.youtube.com/watch?v=lxxOFBgP1II
Note how the bushing extends through the inside links and projects into the outer link. This recess in the outer link that accommodates the bushing is called the counterbore.
This design was thought up by Cat in the early 1930's - prior to that, the bushing ended at the inner link and the track could be separated by knocking out any pin.
When the introduction of the counterbore design, it meant that the track could only be separated at the master pin, where there is a special short bushing (the master bushing) and spacers in the counterbore.
The counterbore design is a superior design to the earlier designs, it has a longer wearing surface between pin and bushing and resists track snaking better.
Regards, Ron.
Wed, Dec 10, 2014 10:57 AM
Reply to OzDozer:
Regards, Ron.
Pin and bushing turning on the smaller machines has become somewhat of a dying practice. Labor cost are causing more tracks to be run to destruction and just being replaced with new. Check with a local track service and see if they want to even be bothered.
Wed, Dec 10, 2014 2:04 PM
Oil Slick
I thought of trying rig something up to rotate the P+B on my D8 but they gave me a quote of $2,600 so I had it done. What a wise decision!
Thu, Dec 11, 2014 12:16 AM
Tom Madden_archive
Reply to Oil Slick:
Thank you Ron that is a great video.
Thu, Dec 11, 2014 1:14 AM
Reply to Tom Madden_archive:
Awesome Video, but they make that look way to easy!
Thu, Dec 11, 2014 6:51 AM
rjh-md
Reply to drujinin:
Turning pins and bushings is still benefical ,and cost effective if done at the proper time ,monitoring the internal pin and bushing ware .The internal ware is in a form of an egg . If the egg internal ware is too great ,its a waist of money to turn the pins and bushings . Turning at the right time sets the track pitch back in ,and increases the life of the pins , internal and external ware on the bushings and sprockets . Sandy and abrasive soils ,and operating speeds cause a more rapid internal ware ,and track machines working in those coditions need to be watched carefully .A contractor with a fleet of track machines can save a considerable amount of money by monitoring internal and external track ware .
Thu, Dec 11, 2014 8:41 AM
Oil Slick
Reply to rjh-md:
rjh, when is the proper time to rotate the P&B?
Thu, Dec 11, 2014 10:53 AM
Jw74
Reply to Oil Slick:
Thanks guys those videos were an eye opener for me...and fun to watch!
Thanks God Bless
Thu, Dec 11, 2014 1:35 PM
rjh-md
Reply to Jw74:
Oil slick , Cat gives chart specs on internal ware measured across serveral links with a pin in the sprocket and machine backed up to take all internal slack out of the track with brakes applied. Measurement is different for different tract pitches .I believe the average turn percentage of internal ware for the time to turn was around 45 tto 50 % internal ware. I need the expertize of a track sales man to verifly this ,as I don't have access to the chart specs
Thu, Dec 11, 2014 7:58 PM
