Trying to identify the Model Caterpillar Dozer by the Serial Number
Showing 1 to 6 of 6 results
mikef
Send a private message to mikef
Hi all,
Just purchased a D5 Dozer with the serial numbers: 31v49789-4n7363
I would like to get Year and model of dozer so I can purchase owner/operator/parts manuals etc.
When I asked the previous owner he said its a 1974 D5.
Thank you in advance for any help you may have.
Mike
Fri, Jul 17, 2015 12:22 PM
Thank you received: 50
31Vxxxx is not a good number.
I think your misreading the 31V as actually being a 3Nxxxx which would designate the engine arrangement 4N7363 as either a 95J398-up (narrow gauge) or 96J4791-up (wide gauge) D5 model tractor in 1974.
Fri, Jul 17, 2015 3:14 PM
mikef
[quote="Old Magnet"]31Vxxxx is not a good number.
I think your misreading the 31V as actually being a 3Nxxxx which would designate the engine arrangement 4N7363 as either a 95J398-up (narrow gauge) or 96J4791-up (wide gauge) D5 model tractor in 1974.[/quote]
Hi,
Thank you for the reply. What is the difference between narrow & wide gauge. With the serial number, how would I find out what model Dozer I have? Thank you again!
Fri, Jul 17, 2015 11:06 PM
Reply to mikef:
Hi,
"Gauge" is the width of the tracks, measured center to center. For the D5, narrow is 60" and wide is 74".
3N49781 is the engine s/n
4N7363 is the engine arrangement
The first three characters in the tractor s/n designate the series (model)
followed by the build sequence number.
Yours is most likely a 96J model as the 95J is less common.
Fri, Jul 17, 2015 11:40 PM
mikef
[quote="Old Magnet"]"Gauge" is the width of the tracks, measured center to center. For the D5, narrow is 60" and wide is 74".
Yours is most likely a 96J model as the 95J is less common.[/quote]
Ok, I found the plate with the serial numbers
D5 96J 6030 8P5568
3306 3N49789 4N7363
Measured the track from center to center and its about 74". "Wide Gauge"
Thank you for your help!
Sun, Jul 19, 2015 10:20 PM
Reply to mikef:
D5 96J 6030 8P5568
3306 3N49789 4N7363
My info shows 96J6030 to be a late 1977 model near end of production.
Would also explain the high engine s/n.
Sun, Jul 19, 2015 11:53 PM
DALEGT500
Send a private message to DALEGT500
The engine number is 7u10130, thanks for any help
Tue, Jul 2, 2019 2:59 AM
