Traxcavator fan belt replacement
Showing 1 to 6 of 6 results
davh
Send a private message to davh
What needs to be split on the hydraulic pump shaft on my Traxcavator to replace the fan belt? I should say what is the best way I have the guards off.
Wed, Aug 12, 2015 6:28 PM
Skip in CT
Send a private message to Skip in CT
you have to pull the pump in the front in order to get the shaft out to replace the belt. Or you could cut it and replace it with a link belt because you can tighten the belt with the pulley.
Skip in CT
Thu, Aug 13, 2015 1:28 AM
davh
Reply to Skip in CT:
Skip in CT
Where is the best place to order a link belt for the D-4?
Thu, Aug 13, 2015 4:50 AM
trucker1
Send a private message to trucker1
Reply to davh:
A lot of guys use Mcmaster Carr. You have to know the top width and then order the length.
http://www.mcmaster.com/#v-belts/=ygxbje
George
Thu, Aug 13, 2015 8:03 AM
davh
Reply to trucker1:
George
I will check them out. Thanks, Dave
Fri, Aug 14, 2015 3:17 AM
Paso Bob
Reply to davh:
Maybe someone will correct me if I'm wrong... If you loader is on a 7U D-4 chassis it will most likely have a #44 two valve pump. I was able to change the fan belt on my 7U by unbolting the pump drive flange from the lower fan belt pulley and pry the shaft forward enough to slip a new belt through.
Fri, Aug 14, 2015 11:58 AM
davh
Reply to Paso Bob:
I took the 8 bolts out on the shaft coupler to the crankshaft between the engine and the radiator ( 8 x 9/16 ). Then I was able to loosen the bolts holding the hydraulic unit in front of the radiator enough (4 x 1 1/8 inside between the hydraulic unit and the radiator) and 4 smaller bolts on side brackets also in front of the radiator ( think they were 15/16 ). This allows the shaft to open just enough to slide the belt through it. The interior of the coupler is full of grease so I did remove as much of the grease as I could before sliding the belt through and then pumped grease back in when I closed the coupler back up. The fan blade was also removed before I could make it all work. Hope this helps someone else. Dave
Mon, Aug 17, 2015 10:16 PM
