Transmission shifting lever repair
Delta KJ
I have a No. 12 grader with some shoddy welding repairs on the transmission and high-low shifting levers.  Are these levers cast iron or cast steel?
Should they be brazed or otherwise?  If they are to be brazed; will they hold up in use?
Mon, Jul 24, 2023 11:26 PM
Thank you received: 55
actually the process for flame welding cast is bronzing.
it is very strong they use the process to repair cast gears so i think it would be more than suitable on a gear lever. but like any process it needs to be done properly.
Tue, Jul 25, 2023 3:44 PM
